Chuck8
#1 Posted : Monday, August 9, 2021 2:20:59 AM(UTC)
Chuck8
I use vMix Replay as a separate external replay system, using the two external outputs to feed my A and B outputs into a router/switcher.
Some directors like to mix between A and B themselves, but others prefer you to use A and B like Preview/Program, and while B is live, be able to 'push on', mixing to the next clip you have prepared in A.
I have previously used the Newtek 3Play, where you could hit the 'take' button, which works like the ReplaySwapChannels button does currently, to swap the A and B channels around.
The 3Play also had an 'auto' button, which would swap the two channels using a transition of your choice.
I appreciate this is no simple task, and there is already a transition system for pgm/pvw in vMix, but the option to have a simple fade between the two channels would be a huge improvement to the workflow.
Perhaps it could be fixed for now, and customisable in the future. 18 frames was my duration of choice!
zaczdt
#2 Posted : Wednesday, August 27, 2025 8:35:09 PM(UTC)
zaczdt
+1
Maybe even using the Event Transition in the replay session for added customization
monamiga
#3 Posted : Wednesday, August 27, 2025 10:17:03 PM(UTC)
monamiga
Philippines
+1
zaczdt
#4 Posted : Tuesday, December 9, 2025 10:45:55 AM(UTC)
zaczdt
+1
