Feature Requests
Fade transition for Replay Swap Channels function
I use vMix Replay as a separate external replay system, using the two external outputs to feed my A and B outputs into a router/switcher.
Some directors like to mix between A and B themselves, but others prefer you to use A and B like Preview/Program, and while B is live, be able to 'push on', mixing to the next clip you have prepared in A.
I have previously used the Newtek 3Play, where you could hit the 'take' button, which works like the ReplaySwapChannels button does currently, to swap the A and B channels around.
The 3Play also had an 'auto' button, which would swap the two channels using a transition of your choice.
I appreciate this is no simple task, and there is already a transition system for pgm/pvw in vMix, but the option to have a simple fade between the two channels would be a huge improvement to the workflow.
Perhaps it could be fixed for now, and customisable in the future. 18 frames was my duration of choice!
Joined: 2/14/2020(UTC) Posts: 29  Location: Brisbane Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
+1
Maybe even using the Event Transition in the replay session for added customization
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 173 times Was thanked: 3 time(s) in 2 post(s)
Feature Requests
