NDI
NDI Output to Rodecaster Video
Joined: 5/7/2024(UTC) Posts: 21  Thanks: 5 times Was thanked: 3 time(s) in 2 post(s)
Have recently purchased a Rodecaster Video, as it now has NDI capabilities
I can get NDI OUT from RCV into VMIX, but I cant seem to get VMIX to RCV via NDI to work.
the RCV sees the NDI Feed under the Network settings (both PC & RCV connected to the same switch via Ethernet), and appears to allow it to be accepted. However, when i look at the RCV it says Unsupported, and with Format being N/A, Video Codec SHQ, Video Sampling unknown, Video Bit Depth Unknown, Alpha Channel Absent, PAR Unknown, (plus a load of other unknowns), Audio Codec PCM, Sample Rate 48.0 khz, Audio Channels 2, Network Interface RJ45 If i change it to RCV NDI, i get the following Format 1920x1080p, Frame Rate 25, Format YUV, Video Codec H264 etc
So it is seeing the NDI Feed, but appears to be incompatable.
I have tried changing NDI Out on VMIX to Alpha Channel None & Premultiplied & Straight, with no success.
Any other suggestions?
Also, has anyone managed to get VMIX Graphics (from GT Titler) to appear with transparent backgrounds into RCV, either as an HDMI Input or NDI? I know you should be able to Greenscreen them out, but my graphics have many colours, so does not really work well with greenscreen
Lee
It's very likely Full NDI or NDI HB versus NDI HX.
Joined: 10/24/2023(UTC) Posts: 29   Location: Südtirol Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
there is an option to convert NDI HB into HX via NDI Bridge.
ok - have managed to get this to work, and in case someone needs to know how I did this, here are the instructions - may not be the most efficient or tidy, but it works for me
VMIX Set up as normal, with NDI Out for relevant 'input' with transparent background, and NDI Settings 'Alpha channel' set to premultiplied
NDI Bridge (take a note of its name) Set to local in Settings and Diagnostics, encoder setting set to NDI/HX and H264 Start
Rodecaster Video Main Camera input into HDMI A (or whatever you prefer). Camera 6 as Network 1, with device set to your NDIBridge (using name, not the VMIX NDI) Key - Set to Alpha Then set a new scene (A to G buttons) Set to multicourse Top Layer Camera 6 (the graphics) 2nd Layer Camera 1 (your video feed) Then choose Button B which should have your Video and graphics. Not sure how you can switch between different camera - possibly setting up individual buttons (A camera 1, B camera 2 etc). Or use HDMI Output (PGM) and use a short HDMI cable and feed into say HDMI 5, and use HDMI 5 as the main footage (which will be PGM). There may be better options but for what I need, this works.
NDI
