thomas.thielen12@gmail.com
#1 Posted : Tuesday, December 2, 2025 2:28:49 AM(UTC)
Germany
I’m planning a new high-end system for vMix and would like to get some feedback before I order everything.
My main goal is long-term stability, multiple PCIe capture cards, and solid 4K performance (a few 4K inputs and two 4K outputs).
Here’s the current hardware plan:
CPU: AMD Ryzen Threadripper 9960X
Mainboard: ASUS Pro WS TRX50-SAGE WIFI
GPU: Gigabyte AORUS GeForce RTX 5080 MASTER 16G
RAM: Kingston Fury Beast DDR5 – 64 GB (2×32 GB), 6000 MHz
CPU Cooler: Noctua NH-D9 TR5-SP6 4U (height limit in the case is 145 mm, so this was basically the only reasonable sTR5 air-cooler option)
Power Supply: be quiet! Straight Power 12 Platinum – 1000 W
Capture Cards (PCIe): Blackmagic DeckLink 8K Pro Mini & 2x Blackmagic DeckLink Quad 2
The board layout should give me enough space for the 5080 (3.5-slot) plus these three PCIe cards without blocking anything.
Before I lock this in:
Does this build make sense for vMix?
Anything you would change? CPU, GPU, cooling, PSU size, RAM amount — or anything else I should consider?
Thanks in advance for any input!
Kayo33
#2 Posted : Wednesday, December 3, 2025 1:42:05 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
by using reference Obtanium vMix system as reference (4k production)
https://www.vmix.com/kno...reference-system-details
You need a better CPU cooler
https://www.noctua.at/en...ketId=39&search=9960
Noctua NH-U14S TR5-SP6
Replace the two Quad 2 cards with DeckLink 8K Pro G2 cards for 4K
DDR5 6400 MHz
ssd M2 pcie 5.0 x4
GPU = 2 slots max
#3 Posted : Wednesday, December 3, 2025 4:41:25 AM(UTC)
Germany
Thanks for the suggestions.
A few points don’t apply to my setup, so just to clarify:
• CPU cooler:
I’m using a 4U rack case with a 145 mm height limit. The NH-U14S TR5 doesn’t fit.
The NH-D9 TR5-SP6 4U is the correct cooler for this form factor.
• Capture cards:
I need many HD-SDI inputs, not multiple 4K streams.
Replacing the Quad 2 with 8K Pro G2 would cut my input count in half, so that won’t work for my workflow.
I already have 4K covered via the 8K Pro Mini.
• RAM
6000 MHz RAM is stable on TRX50 and more than enough for vMix.
Thanks again for your input!
