guidogast
#1 Posted : Monday, November 3, 2025 4:48:01 AM(UTC)
guidogast
Netherlands
Was thanked: 36 time(s) in 24 post(s)
The new trigger OnCountdownRemaining is lacking in documentation on https://www.vmix.com/help29/ and I don't think it's working correctly.
Reproduction steps:
1. Create a title with this value: {0:7:45 PM|HH:mm:ss} (use the time that's closest to you to fire the trigger quickly)
2. Set an OnCountdownRemaining trigger on that title
2.1 00:00:20
2.2 Function: Fade
2.3 Input: Preview
The above settings intuitively seem to suggest that when 20 seconds are remaining on the countdown, the trigger must fire. However, it does absolutely nothing. Seems like a bug to me? And if it's not a bug, can the documentation be updated to tell us how this works exactly with possible caveats (it doesn't work the way I described above)
dmwkr
#2 Posted : Monday, November 3, 2025 9:08:59 AM(UTC)
dmwkr
Countdown triggers only work on countdowns configured in the settings of the title editor, not on the countdown to time function.
guidogast
#3 Posted : Wednesday, November 5, 2025 7:35:42 PM(UTC)
guidogast
Netherlands
Thanks for clarifying. I suppose the docs are not updated yet. As it would be nice to read that in there, so posting here would not be necessary. I created a Feature Request post for this :) Thanks again!
