OnCountdownRemaining question
Joined: 5/19/2017(UTC) Posts: 106   Location: The Netherlands Thanks: 16 times Was thanked: 36 time(s) in 24 post(s)
The new trigger OnCountdownRemaining is lacking in documentation on https://www.vmix.com/help29/ and I don't think it's working correctly. Reproduction steps: 1. Create a title with this value: {0:7:45 PM|HH:mm:ss} (use the time that's closest to you to fire the trigger quickly) 2. Set an OnCountdownRemaining trigger on that title 2.1 00:00:20 2.2 Function: Fade 2.3 Input: Preview The above settings intuitively seem to suggest that when 20 seconds are remaining on the countdown, the trigger must fire. However, it does absolutely nothing. Seems like a bug to me? And if it's not a bug, can the documentation be updated to tell us how this works exactly with possible caveats (it doesn't work the way I described above)
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Countdown triggers only work on countdowns configured in the settings of the title editor, not on the countdown to time function.
Originally Posted by: dmwkr  Countdown triggers only work on countdowns configured in the settings of the title editor, not on the countdown to time function. Thanks for clarifying. I suppose the docs are not updated yet. As it would be nice to read that in there, so posting here would not be necessary. I created a Feature Request post for this :) Thanks again!
