SRT
Srt Caller Black & Freeze
hi I created one caller in Vmix. The project is 1080 25p. The IP and port information is correct. The stream appears to be coming in at 6mbit as shown in the attachment. The other side's encoder settings are shown in green. However, in Vmix, the input only appears as 25p and black. The resolution appears to be 32x32. The Vmix version was 29. I also tried 28.x.x.x, but it didn't work. If you refresh the srt input in Vmix, Vmix completely freezes. Could this be a video codec issue? I can solve the same stream on OBS.  WhatsApp Image 2025-11-01 at 14.29.16.jpg (171kb) downloaded 66 time(s). WhatsApp Image 2025-11-01 at 14.27.48.jpg (179kb) downloaded 66 time(s). WhatsApp Image 2025-11-01 at 14.29.11.jpg (289kb) downloaded 66 time(s).
@ f2s
Can you clarify what the incoming source is? Your screenshot appears to indicate 1080i25. AFAIK, vMix only supports progressive SRT streams, not interlaced streams.
Joined: 2/17/2021(UTC) Posts: 18  Location: Oslo Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hi, We are seeing the exact same issue as you are seeing. Using an Intinor encoder, 1080p output profile. "32x32 resolution" on the input. Also tried version 25, 28 and 29. I have also tried using the VLC input for SRT in vmix. Then the decoder manages to decode audio, but not video. When using VLC on the same machine. Everything works fine. In 29 we get an error message in the srt settings SRT.ExitingDueToDecoderFailure SRTConnectionSocketThread
 image (30).png (80kb) downloaded 45 time(s). image (31).png (67kb) downloaded 44 time(s). image (32).png (186kb) downloaded 44 time(s).
I came to the following conclusion. When sent as 1080 interlaced on the encoder side, I think it cannot decode because there is no interlaced support on the vmix side. When you set the encoder to Progressive, there is no problem. I came to this conclusion as a result of my experiments. Perhaps someone with definitive knowledge can verify this. I think vmix does not support interlaced in the SRT protocol.
Joined: 3/21/2022(UTC) Posts: 52  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: f2s  I came to the following conclusion. When sent as 1080 interlaced on the encoder side, I think it cannot decode because there is no interlaced support on the vmix side. When you set the encoder to Progressive, there is no problem. I came to this conclusion as a result of my experiments. Perhaps someone with definitive knowledge can verify this. I think vmix does not support interlaced in the SRT protocol.
Interlaced is a special signal mode that was/is very common in the TV industry. It's saving some bandwith on the signal, but is seldom used in the computer world. If you can, try to avoid it. It gets worse when you use H.265. There is some mention of interlaced mode in the H.265 standard, but it is seldom used and can cause a lot of problems. Hope this helps, Chris
SRT
