#1 Posted : Saturday, August 16, 2025 6:36:03 PM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
vMix 29 Preview (29.0.0.19 Beta) is here!
Disclaimer: This is a preview release for those who like to live on the edge! There will still be some bugs, so it should not be used in productions.
Your feedback is greatly appreciated, please report any bugs or issues in the Beta Discussion forum.
Updates: If you purchased vMix prior to 1 January 2023, an additional purchase is required to use this beta or a new Trial may be possible if you have only used the Trial once in the past. Finally, an edition upgrade (say from HD to 4K) will also include 12 months of free updates.
https://account.vmix.com/order/?Upgrade=1
Note: New features should not be submitted here, please use the Feature Requests forum instead.
Download Links
https://cdn.vmix.com/download/vmix29.exe
Zoom Plugin for vMix
https://www.vmix.com/zoomplugindownload
New Features and Changes
Open Media Transport (OMT) support
* New open source protocol for sending and receiving high quality audio and video over a gigabit LAN.
* Full 4K and high frame rate support (120fps+)
* Supports direct recording to Instant Replay and MultiCorder (vMix AVI) without re-encoding, saving on CPU.
* Support for Low, Medium and High quality presets, providing options for both lower and higher bandwidth than competing protocols.
* Built in fault tolerance, handles corrupt video data gracefully.
* More information and free tools for both Mac and pc available at https://www.openmediatransport.org/
Instant Replay
* CPU usage for both recording and playback substantially reduced by up to 50%
* New Configure Storage option allows selecting separate drives for individual camera recordings.
* Add multiple tags to events
* Drag and drop events to list folders
* New Quad View mode allows viewing four separate camera angles on screen at a time in high quality (via Replay MultiView)
* New Activators: ReplayLive, ReplayChannelAB, ReplayChannelA, ReplayChannelB, ReplayQuadMode
* New Shortcuts: ReplayToggleQuadMode, ReplayQuadModeOn, ReplayQuadModeOff, ReplayAppendLastEventText, ReplayAppendLastEventTextCamera, ReplayAppendSelectedEventText, ReplayAppendSelectedEventTextCamera
* Added configurable audio source option when exporting clips
New Overlay Channels
* Increased number of overlays to 8 up from 4 (in HD and higher editions)
* Also increased number of stingers to 8.
* Updated input buttons to support new overlays
* New shortcuts added
Remember vMix GO? It's back, in POG form (Programmable option gateway)!
* Replaces QuickPlay button under each input with a new customisable action.
* Defaults to QuickPlay but also supports transitions or a fully customisable shortcut.
Audio
* Five new audio bus configurations available: AB, CD, DE, ABCD and DEFG
* All audio bus options now selectable for MultiCorder in addition to Master
Search
* Added participant search to the Zoom Manager
* Added search to the List input editor
Triggers
* New OnCountdownTime and OnCountdownRemaining, allow triggers on Title countdowns.
Documentation
https://help.vmix.com/29/
thanks 21 users thanked admin for this useful post.
jet on 8/16/2025(UTC), robertskiba on 8/16/2025(UTC), nikosman88 on 8/16/2025(UTC), doggy on 8/16/2025(UTC), vijay6672 on 8/16/2025(UTC), ryxyz on 8/16/2025(UTC), fgolman on 8/16/2025(UTC), berryv97 on 8/17/2025(UTC), avsoundguy on 8/17/2025(UTC), Harness on 8/17/2025(UTC), TinyBear on 8/17/2025(UTC), EscapingKid on 8/17/2025(UTC), tsioukas on 8/18/2025(UTC), eduardocfs on 8/19/2025(UTC), Luackie on 8/19/2025(UTC), eee8bit on 8/19/2025(UTC), stevespaw on 8/20/2025(UTC), monamiga on 8/27/2025(UTC), Ario on 9/16/2025(UTC), dunk on 9/16/2025(UTC), StepBackInTime_TV on 9/18/2025(UTC)
#2 Posted : Sunday, August 17, 2025 3:18:15 AM(UTC)
vMix 29.0.0.20 Beta
* Fixed GO shortcuts not linking to correct inputs when moved
* Fixed Replay video only mode not updating screens while recording
* Added Overlay5-8 to Mouse Click Actions
* Fix for ReplayCCamera ReplayDCamera shortcuts
* Fixed incorrect tooltip on GO buttons
thanks 12 users thanked admin for this useful post.
berryv97 on 8/17/2025(UTC), Eapgh on 8/17/2025(UTC), doggy on 8/17/2025(UTC), jet on 8/17/2025(UTC), avsoundguy on 8/17/2025(UTC), ryxyz on 8/17/2025(UTC), Harness on 8/17/2025(UTC), TinyBear on 8/17/2025(UTC), nikosman88 on 8/18/2025(UTC), robertskiba on 8/18/2025(UTC), eduardocfs on 8/19/2025(UTC), eee8bit on 8/19/2025(UTC)
#3 Posted : Monday, August 18, 2025 11:12:40 PM(UTC)
vMix 29.0.0.21 Beta
* Fixed Twitch Chat not working in vMix Social
* Added support for changing the Quality setting on an OMT Output.
Setting this to something other than Default overrides any receivers selection
* Input search now also searches the files within a List input
* Fixed missing Overlay5-8 activators
* Various OMT reliability fixes
thanks 8 users thanked admin for this useful post.
jet on 8/19/2025(UTC), eduardocfs on 8/19/2025(UTC), ryxyz on 8/19/2025(UTC), doggy on 8/19/2025(UTC), Soundfloss on 8/19/2025(UTC), eee8bit on 8/19/2025(UTC), QuiapoChurch on 8/20/2025(UTC), Peter1000 on 8/21/2025(UTC)
#4 Posted : Thursday, August 21, 2025 1:00:04 PM(UTC)
vMix 29.0.0.22 Beta
* Fixed new Overlay / Stinger settings getting mixed up with presets from previous versions.
If you've saved presets in 29 containing Overlay5-8 or Stinger5-8 settings these will need to be recreated again.
Otherwise, settings from 28 and older and from 29.22 can now be moved between versions without issues.
thanks 3 users thanked admin for this useful post.
jet on 8/21/2025(UTC), Soundfloss on 8/21/2025(UTC), eduardocfs on 8/25/2025(UTC)
#5 Posted : Monday, August 25, 2025 12:53:56 PM(UTC)
vMix 29.0.0.24 Beta
* Added Audio Bus filter for OMT
* Added -20dB Pad option for OMT Inputs
* Added m4a and mkv to defaults for FFMPEG decoder
* Fixed spurious "OMT" and "NDI" sources created when Additional Outputs enabled
* Fixed missing omt property in API XML
* Fixed Web Controller not working correctly due to additional Overlays
* Added OMT to MultiView sorting by Camera
* Updated OMT libraries with improved discovery of MacOS sources
thanks 4 users thanked admin for this useful post.
jet on 8/25/2025(UTC), robertskiba on 8/25/2025(UTC), eduardocfs on 8/25/2025(UTC), monamiga on 8/27/2025(UTC)
#6 Posted : Thursday, August 28, 2025 4:56:42 PM(UTC)
vMix 29.0.0.25 Beta
* Added support for WebP to Image and Photos inputs
* Fix for Replay channels C and D not showing live sources when Show live sources checkbox enabled in settings
* Fixed issue with previews not updating correctly when Show only video setting toggled while in Live mode.
* New AlphaFade transition effect that applies an opposite fade to current input alongside preview input. This looks better with alpha channel sources, but will result in a slight brightness dip at the mid point so not
recommended for general purpose use.
thanks 13 users thanked admin for this useful post.
doggy on 8/28/2025(UTC), jet on 8/28/2025(UTC), robertskiba on 8/28/2025(UTC), QuiapoChurch on 8/28/2025(UTC), nikosman88 on 8/28/2025(UTC), monamiga on 8/28/2025(UTC), WaltG12 on 8/29/2025(UTC), ryxyz on 8/29/2025(UTC), eduardocfs on 8/30/2025(UTC), Chircanu on 9/1/2025(UTC), Soundfloss on 9/8/2025(UTC), dunk on 9/16/2025(UTC), sinc747 on 9/18/2025(UTC)
#7 Posted : Sunday, September 21, 2025 6:20:33 PM(UTC)
vMix 29.0.0.28 Beta
* New Zoom Events support. Requires a new updated Zoom Plugin available from https://www.vmix.com/zoomplugindownload/
* New ability to disable thumbnail generation for Photos. This can speed up loading Photos inputs where the thumbnail selection feature is not needed.
* Fix for new bus selections ABCD and DEFG not working correctly.
* Fix for Image Sequences not updating through data sources when Continuous Image Sequence animation selected
* Fix for SetTransitionEffect with new stingers
* Fix for PlayList selection for new stingers
* Fix for Replay selection for new stingers
* Fix for OMT inputs not reconnecting in the case of a network or power cable unplugged at the source.
* Improvement to SRT multi-track audio handling in cases where the source encoder encodes tracks in random or inconsistent stream order.
thanks 7 users thanked admin for this useful post.
Peter1000 on 9/21/2025(UTC), jet on 9/21/2025(UTC), Jurgen on 9/22/2025(UTC), QuiapoChurch on 9/22/2025(UTC), Chircanu on 9/22/2025(UTC), monamiga on 9/23/2025(UTC), Soundfloss on 9/25/2025(UTC)
#8 Posted : Tuesday, September 30, 2025 1:25:24 PM(UTC)
vMix 29.0.0.29 Beta
* Hover over GO button to see what action it will take
* NDI / OMT Add Input list was not sorted correctly
* Disabled statistics reset button for tabs where it is not supported
* Added OMTPreviewOn, OMTPreviewOff shortcuts
* Improved accuracy in general of Replay recording time remaining calculation. Also now works based on number of cameras only on session drive, so will be more accurate
where some cameras have been assigned to different storage.
* Twitch streaming destination update to support new Default server option
* Fix for missing input scroll bars when Update Available link visible
thanks 5 users thanked admin for this useful post.
jet on 9/30/2025(UTC), QuiapoChurch on 9/30/2025(UTC), ryxyz on 9/30/2025(UTC), nikosman88 on 10/1/2025(UTC), monamiga on 10/2/2025(UTC)
#9 Posted : Thursday, October 9, 2025 12:34:56 PM(UTC)
vMix 29.0.0.31 Beta
* Increased SRT audio track combining buffer for streams with out of order video encoding profiles.
* Fix for OMT error when opening multiple instances of vMix
* Fix for Overlay Settings window hiding options when switching between a GT Stinger and a normal overlay.
* Better calculations for hiding buttons in transition bar area when space is not available.
* Fix for StreamID not being remembered in recent list for adding SRT inputs
jet on 10/9/2025(UTC), monamiga on 10/10/2025(UTC)
#10 Posted : Tuesday, October 14, 2025 7:32:51 PM(UTC)
vMix 29.0.0.32 Beta
* Fix for error when adding new Replay input
* Fixed typo in shortcut description for OverlayInput1In
* Fix when turning on multiple overlays of the same animated input at the same time
MickeyMJJ on 10/14/2025(UTC), doggy on 10/14/2025(UTC), monamiga on 10/14/2025(UTC), jet on 10/14/2025(UTC), berryv97 on 10/15/2025(UTC)
#11 Posted : Tuesday, October 21, 2025 12:25:38 PM(UTC)
vMix 29.0.0.33 Beta
* Fix Replay export issue when recordings are on separate storage
* If separate storage is no longer available, recordings will now divert to main session folder.
* Replay system requirements link now uses latest help file
jet on 10/21/2025(UTC), ON.tv Channels on 10/24/2025(UTC), monamiga on 10/25/2025(UTC), Soundfloss on 10/27/2025(UTC)
Guest (4)
