#1 Posted : Saturday, August 16, 2025 6:36:03 PM(UTC)
Views messages in topic : 5,210
Was thanked: 4518 time(s) in 1571 post(s)
vMix 29 Preview (29.0.0.19 Beta) is here!
Disclaimer: This is a preview release for those who like to live on the edge! There will still be some bugs, so it should not be used in productions.
Your feedback is greatly appreciated, please report any bugs or issues in the Beta Discussion forum.
Updates: If you purchased vMix prior to 1 January 2023, an additional purchase is required to use this beta or a new Trial may be possible if you have only used the Trial once in the past. Finally, an edition upgrade (say from HD to 4K) will also include 12 months of free updates.
https://account.vmix.com/order/?Upgrade=1
Note: New features should not be submitted here, please use the Feature Requests forum instead.
Download Links
https://cdn.vmix.com/download/vmix29preview.exe
Zoom Plugin for vMix
https://www.vmix.com/zoomplugindownload
New Features and Changes
Open Media Transport (OMT) support
* New open source protocol for sending and receiving high quality audio and video over a gigabit LAN.
* Full 4K and high frame rate support (120fps+)
* Supports direct recording to Instant Replay and MultiCorder (vMix AVI) without re-encoding, saving on CPU.
* Support for Low, Medium and High quality presets, providing options for both lower and higher bandwidth than competing protocols.
* Built in fault tolerance, handles corrupt video data gracefully.
* More information and free tools for both Mac and pc available at https://www.openmediatransport.org/
Instant Replay
* CPU usage for both recording and playback substantially reduced by up to 50%
* New Configure Storage option allows selecting separate drives for individual camera recordings.
* Add multiple tags to events
* Drag and drop events to list folders
* New Quad View mode allows viewing four separate camera angles on screen at a time in high quality (via Replay MultiView)
* New Activators: ReplayLive, ReplayChannelAB, ReplayChannelA, ReplayChannelB, ReplayQuadMode
* New Shortcuts: ReplayToggleQuadMode, ReplayQuadModeOn, ReplayQuadModeOff, ReplayAppendLastEventText, ReplayAppendLastEventTextCamera, ReplayAppendSelectedEventText, ReplayAppendSelectedEventTextCamera
* Added configurable audio source option when exporting clips
New Overlay Channels
* Increased number of overlays to 8 up from 4 (in HD and higher editions)
* Also increased number of stingers to 8.
* Updated input buttons to support new overlays
* New shortcuts added
Remember vMix GO? It's back, in POG form (Programmable option gateway)!
* Replaces QuickPlay button under each input with a new customisable action.
* Defaults to QuickPlay but also supports transitions or a fully customisable shortcut.
Audio
* Five new audio bus configurations available: AB, CD, DE, ABCD and DEFG
* All audio bus options now selectable for MultiCorder in addition to Master
Search
* Added participant search to the Zoom Manager
* Added search to the List input editor
Triggers
* New OnCountdownTime and OnCountdownRemaining, allow triggers on Title countdowns.
Documentation
https://help.vmix.com/29/
thanks 14 users thanked admin for this useful post.
jet on 8/16/2025(UTC), robertskiba on 8/16/2025(UTC), nikosman88 on 8/16/2025(UTC), doggy on 8/16/2025(UTC), vijay6672 on 8/16/2025(UTC), ryxyz on 8/16/2025(UTC), fgolman on 8/16/2025(UTC), berryv97 on 8/17/2025(UTC), avsoundguy on 8/17/2025(UTC), Harness on 8/17/2025(UTC), TinyBear on 8/17/2025(UTC), EscapingKid on 8/17/2025(UTC), tsioukas on 8/18/2025(UTC), eduardocfs on 8/19/2025(UTC)
#2 Posted : Sunday, August 17, 2025 3:18:15 AM(UTC)
vMix 29.0.0.20 Beta
* Fixed GO shortcuts not linking to correct inputs when moved
* Fixed Replay video only mode not updating screens while recording
* Added Overlay5-8 to Mouse Click Actions
* Fix for ReplayCCamera ReplayDCamera shortcuts
* Fixed incorrect tooltip on GO buttons
thanks 11 users thanked admin for this useful post.
berryv97 on 8/17/2025(UTC), Eapgh on 8/17/2025(UTC), doggy on 8/17/2025(UTC), jet on 8/17/2025(UTC), avsoundguy on 8/17/2025(UTC), ryxyz on 8/17/2025(UTC), Harness on 8/17/2025(UTC), TinyBear on 8/17/2025(UTC), nikosman88 on 8/18/2025(UTC), robertskiba on 8/18/2025(UTC), eduardocfs on 8/19/2025(UTC)
#3 Posted : Monday, August 18, 2025 11:12:40 PM(UTC)
vMix 29.0.0.21 Beta
* Fixed Twitch Chat not working in vMix Social
* Added support for changing the Quality setting on an OMT Output.
Setting this to something other than Default overrides any receivers selection
* Input search now also searches the files within a List input
* Fixed missing Overlay5-8 activators
* Various OMT reliability fixes
thanks 4 users thanked admin for this useful post.
jet on 8/19/2025(UTC), eduardocfs on 8/19/2025(UTC), ryxyz on 8/19/2025(UTC), doggy on 8/19/2025(UTC)
