MPEG TS Recording quality drop on 13.0.0.142 x64
Joined: 2/26/2014(UTC) Posts: 83  Location: Canada Thanks: 18 times Was thanked: 16 time(s) in 16 post(s)
Hi
I got serious MPEG TS Recording quality drop on 13.0.0.142 x64 from 12
looks like 10 Mbps when i record 25 Mbps TS!i was happy with quality before version 13
i can document more but am i alone with this bad feeling?
Daniel, vMix addict.
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Do you have some examples, perhaps screenshots to demonstrate? One thing to check is to make sure the Size/Resolution set in vMix is the same, as some settings may have changed between versions. For example check the Output Size in Settings and also check the Size for the recording.
Thanks! you fixed it in 14.0.0.8
