daniel514
#1 Posted : Thursday, September 4, 2014 1:08:09 PM(UTC)
daniel514
Canada
Was thanked: 16 time(s) in 16 post(s)
Hi
I got serious MPEG TS Recording quality drop on 13.0.0.142 x64 from 12
looks like 10 Mbps when i record 25 Mbps TS!i was happy with quality before version 13
i can document more but am i alone with this bad feeling?
Daniel, vMix addict.
#2 Posted : Thursday, September 4, 2014 11:19:17 PM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Do you have some examples, perhaps screenshots to demonstrate?
One thing to check is to make sure the Size/Resolution set in vMix is the same, as some settings may have changed between versions.
For example check the Output Size in Settings and also check the Size for the recording.
#3 Posted : Friday, September 5, 2014 10:11:55 PM(UTC)
I have discovered a quality issue that is fixed in the vMix 14 Preview version downloadable below:
http://forums.vmix.com.au/default.aspx?g=posts&m=12015#post12015
Can you test it out and see if there is any improvement?
Thanks,
daniel514
#4 Posted : Friday, September 26, 2014 8:48:46 PM(UTC)
daniel514
Canada
Thanks! you fixed it in 14.0.0.8
