Hardware Compatibility
Output not initialized on startup - vMix restart is required to initalize output correcltly
Joined: 11/14/2012(UTC) Posts: 295  Location: Finland Thanks: 165 times Was thanked: 15 time(s) in 13 post(s)
Just installed the new vMix 29.0.0.31 Beta and the latest BMD drivers (Desktop Video 15.1) and noticed the behaviour described in the topic subject.
The output (and input) card is BMD Micro (M.2).
This issue is repeatable.
My guess is that vMix gives not enough time to the I/O card to be initalized correctly before it goes ahead with other things.
Joined: 1/13/2010(UTC) Posts: 5,253  Location: Gold Coast, Australia Was thanked: 4587 time(s) in 1587 post(s)
Moved this to Hardware Compatibility as we cannot replicate this and Decklink API behavior has not changed in vMix 29. My guess is some kind of issue with that particular device or system.
Martin vMix
The weird thing is that when vMix quitted 1st time then the Output IS Awakened / initialized on exit.
Really, really weird. Today vMix output worked right away, without the need to quit and re-run vMix.. (I did not yet update to the latest beta).
Now Output seems to work great with SDI Level A and latest vMix 29.0.0.32 Beta
