8K?
WaltG12
#1 Posted : Saturday, August 30, 2025 2:40:07 AM(UTC)
WaltG12
I just noticed, for the first time, 8K in the resolution selection, though as a 4K license holder, I'm not eligible to try it.
Will there be a new tier? Or will it be used to further differentiate Pro/Max from 4K?
Or was it just an inadvertent inclusion from a testing phase that didn't make the cut?
SF_Jeffry
#2 Posted : Thursday, October 9, 2025 12:18:51 PM(UTC)
SF_Jeffry
China
+1
#3 Posted : Saturday, October 11, 2025 6:23:41 PM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
This is not new in vMix 28, and in fact you can select these resolutions just fine in vMix Pro or Max (not vMix 4K).
The reason it is not documented is because in the real world is 8k not all that usable, even on the very latest hardware, so it is there
to facilitate each testing by 3rd parties.
SF_Jeffry
#4 Posted : Sunday, October 12, 2025 1:42:43 AM(UTC)
SF_Jeffry
China
Originally Posted by: admin Go to Quoted Post
This is not new in vMix 28, and in fact you can select these resolutions just fine in vMix 4k or above.
Thank you for your reply. During use, I found that creating an 8K project is not allowed, as I am a user of the vMix 4K version.
WaltG12
#5 Posted : Sunday, October 12, 2025 11:25:05 AM(UTC)
WaltG12
I get the same error--hence my earlier inquiry about version compatibility.
#6 Posted : Sunday, October 12, 2025 11:37:05 AM(UTC)
Apologies, I have corrected my reply, vMix 4K does not support 8K, you will need Pro or Max
SF_Jeffry
#7 Posted : Sunday, October 12, 2025 4:40:30 PM(UTC)
SF_Jeffry
China
Thank you very much for the explanation. If possible, please mark it clearly directly in the version description.
spino
#8 Posted : Monday, October 13, 2025 3:27:12 PM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
+1
#9 Posted : Monday, October 13, 2025 6:17:51 PM(UTC)
Please note that 8K is still not officially supported by vMix so will not be mentioned in any documentation as a result.
It is available in the dropdown list for testing only, but officially vMix is only supported for use in up to 4K productions.
Similar Topics
When will the output resolution be 8K?Really looking forward to. (Feature Requests)
by szxtcel 10/17/2019 12:09:29 PM(UTC)
Blackmagic Decklink 8K? (Hardware Compatibility)
by rinaldo 6/24/2018 7:12:02 PM(UTC)
