Reordering Mixes changes mix numbers
Joined: 9/21/2018(UTC) Posts: 23 Location: United Arab Emirates
We have a show with multiple mixes that we tried to move around to change the input ordering visually but this caused the mix numbers to change which then caused out companion presets to change and companion froze as it was referencing previous mix numbers. The labeling for the mixes in vMix at this point started to act strange. Is there a way this can be corrected where the mixes retain the number based on the order they were created?
Joined: 1/13/2010(UTC) Posts: 5,374  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
It is crucial for reliability and manageability that the mix numbers always match the order of the inputs. Therefore you will need to look at changing the references to these mix inputs directly if you need to rearrange things.
Originally Posted by: admin  It is crucial for reliability and manageability that the mix numbers always match the order of the inputs. Therefore you will need to look at changing the references to these mix inputs directly if you need to rearrange things.
so this is more in how the mixes are managed when being created? Is there anyway to reference an absolute rather than value that changes?
I guess you would need to explain the specific use case so we can suggest how to manage things. (For example, what was the reason you needed to move the mix inputs order around in a preset after configuring everything?)
The mix inputs are always in a fixed number order, if you rearrange them in the inputs list, that will re-arrange the number order so it always sequential which logically makes sense.
Joined: 5/15/2022(UTC) Posts: 19  Location: Ohio Was thanked: 2 time(s) in 2 post(s)
If you really need to move the order of inputs around, just make sure any mix inputs you have built remain in the same order. I always put the mix number in the name of the input to make sure they remain in the same order. You could always move them around so they are in mix numerical order but just make sure that your mix 3 precedes mix 4.
