Joined: 8/27/2025(UTC) Posts: 3  Location: Fresno, Ca
How to create a shape (rectangle) in GT Designer, and have it show up as a source in UTC. I want to use as a background for a power play timer and once the timer is finished have it fade away. The only thing I cannot do is see the rectangle in UTC.
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: Kala  How to create a shape (rectangle) in GT Designer, and have it show up as a source in UTC. I want to use as a background for a power play timer and once the timer is finished have it fade away. The only thing I cannot do is see the rectangle in UTC. Can you see it in vMix? If you can't, then you need to uncheck the "Hidden" box.
yes, I can see in GT but in UTC it does not show up as source file. I have unchecked Hidden in GT
