Kala
#1 Posted : Wednesday, September 10, 2025 12:37:52 AM(UTC)
Kala
How to create a shape (rectangle) in GT Designer, and have it show up as a source in UTC. I want to use as a background for a power play timer and once the timer is finished have it fade away. The only thing I cannot do is see the rectangle in UTC.
WaltG12
#2 Posted : Wednesday, September 10, 2025 3:01:55 AM(UTC)
WaltG12
Can you see it in vMix?
If you can't, then you need to uncheck the "Hidden" box.
Kala
#3 Posted : Wednesday, September 10, 2025 5:11:46 AM(UTC)
Kala
yes, I can see in GT but in UTC it does not show up as source file. I have unchecked Hidden in GT
