Recording Quality and Settings
I am still getting used to Vmix after using OBS and Wirecast for quite a few years. I recorded an American football game last night using h.264HIGH at 8mbps using the hardware encoder on my RTX4060.
I am disappointed in the resulting video quality. I see quite a bit of blocking artifacts on fade transitions and a general smudgy look to portions of the frame. 8mbps with my older 1660TI Nvidia card using Wirecast or OBS resulted in very nice recordings with no blocking artifacts.
The recording settings are kind of sparce in comparison to the streaming settings where one can choose P7 for the highest quality. Is there anything I am missing? Vmix seems like such well put together software I would not expect sub-par quality recordings. I need to keep the recordings in MP4 as they are sometimes deliverables and file sizes need to be kept on the low side.
Thanks for your help!
Joined: 7/4/2021(UTC) Posts: 413  Thanks: 9 times Was thanked: 59 time(s) in 50 post(s)
You didn't mention what resolution/frame rate you're using, but H264 at 8Mbps seems really low, especially for something like sports where there's constant motion. I probably wouldn't go below 32Mbps for 1080p60.
This isn't something like a talk show where they're just sitting at a desk and barely moving.
Maybe try switching to HEVC and also bumping that 8 to something larger.
But no matter what you do, until you hit a certain point, your quality will be proportional to your file size. Even with the most efficient codec, the file can only get so small before you start running into problems like you're describing.
Thanks for your reply. Sorry, I did not mention it is at 1080p60.
But I did mention that I have been using 8mbps with Nvenc for years without any of the artifacting I am seeing in this week's recoding. While less compression is always better, 8mbps is plenty of bitrate to avoid macro blocking on cross fade transitions.
I am hoping to equal the quality of my previous software/hardware with Vmix and hoping that there are some more settings in the record area to achieve this.
Joined: 10/31/2020(UTC) Posts: 186  Thanks: 4 times Was thanked: 42 time(s) in 41 post(s)
I don't work for vMix, I'm only posting my guess as to what is going on, and why you are seeing different results.
I bet the difference is OBS is probably using variable bitrate, and when you set 8Mbps, that's the average, and it is allowed to jump up higher than that for certain scenes (lots of motion or transitions).
I bet vMix is using constant bitrate, or possibly variable bitrate, but the 8Mbps is probably a hard cap. So even if you set 8Mbps on both, I bet the resulting file size on vMix is probably smaller. If you raise the bitrate in vMix to give you similar filesize as what you would get in OBS, the bitrate number might be higher (who cares, it's just a number) but the filesize is similar and probably has similar quality.
I don't know for certain, but that's probably what's going on. I would do some experiments and see if vMix is actually making similar file sizes when you set both to 8Mbps.
-- Kevin
Thanks for your reply. That could be the case. I see that Vmix has a forced CBR button in dialogue box, so that makes me think it is using VBR unless the button is checked. I am in contact with support to make sure all of my project/program settings are set correctly. Hopefully it will be resolved as some kind of user error instead of the program being at fault.
