Joined: 9/10/2020(UTC) Posts: 7   Location: Ahmedabad
AUTOMATIC PLAY EXCEL DATA IN COLUMN A TO B,C,D,E,F.... WHEN WE PLAY AUTO NEXT IN EXCEL SHEET SYSTEM PLAY COLUMN 1 AND ROW 1,2, 3,4 BUT I PLAY COLUMN 1-1 AFTER COLUMN -  EXEL DATA.png (23kb) downloaded 81 time(s). 2-1 ,COLUMN - 3-1 ETC AS PER EXAMPLE EXCEL SHEET HOW TO PLAY 101->201->301->401->501 WHAT IS PROSSES
Joined: 12/27/2012(UTC) Posts: 5,442  Location: Belgium Thanks: 309 times Was thanked: 1002 time(s) in 828 post(s)
There is no reason to SHOUT !
would advice to have another look on how datasources can/need to be used and maybe the convert rows to columns might be an options Best option would be to restructure your excel file Of you are familiare with scripting ( coding) you could make some elaborate code to do what you want
scripting ( coding) PLS GIVE ME I DONT KNOW
CHANGE COLUMN A TO B,C,D,E,F.....
Joined: 4/23/2017(UTC) Posts: 1,371  Location: Germany Thanks: 3 times Was thanked: 184 time(s) in 165 post(s)
The datasorce is using row by row. Not column by column.
What comes to my mind is to use two dynamic variables. One for row and one for column.
Joined: 5/14/2013(UTC) Posts: 146  Location: uk Thanks: 2 times Was thanked: 26 time(s) in 22 post(s)
Do a v lookup with a drop down in the excel to put whatever data you want into the cells Vmix is looking at
 1 user thanked Henny for this useful post.
Originally Posted by: doggy  There is no reason to SHOUT ! would advice to have another look on how datasources can/need to be used and maybe the convert rows to columns might be an options Best option would be to restructure your excel file Of you are familiare with scripting ( coding) you could make some elaborate code to do what you want. OneBloodRewards I totally agree, no need to shout! Thanks for the advice — I’ll definitely check out the datasource options and see if converting rows to columns works better. Restructuring the Excel file might be a good idea too. I’m familiar with coding, so I’ll consider writing a script if needed. Appreciate the input!
