Joined: 9/10/2020(UTC) Posts: 8   Location: Ahmedabad
AUTOMATIC PLAY EXCEL DATA IN COLUMN A TO B,C,D,E,F.... WHEN WE PLAY AUTO NEXT IN EXCEL SHEET SYSTEM PLAY COLUMN 1 AND ROW 1,2, 3,4 BUT I PLAY COLUMN 1-1 AFTER COLUMN -  EXEL DATA.png (23kb) downloaded 82 time(s). 2-1 ,COLUMN - 3-1 ETC AS PER EXAMPLE EXCEL SHEET HOW TO PLAY 101->201->301->401->501 WHAT IS PROSSES
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
There is no reason to SHOUT !
would advice to have another look on how datasources can/need to be used and maybe the convert rows to columns might be an options Best option would be to restructure your excel file Of you are familiare with scripting ( coding) you could make some elaborate code to do what you want
scripting ( coding) PLS GIVE ME I DONT KNOW
CHANGE COLUMN A TO B,C,D,E,F.....
Joined: 4/23/2017(UTC) Posts: 1,481  Location: Germany Thanks: 3 times Was thanked: 196 time(s) in 176 post(s)
The datasorce is using row by row. Not column by column.
What comes to my mind is to use two dynamic variables. One for row and one for column.
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Do a v lookup with a drop down in the excel to put whatever data you want into the cells Vmix is looking at
 1 user thanked Henny for this useful post.
