Guycochran
#1 Posted : Friday, August 22, 2025 11:55:12 PM(UTC)
Guycochran
What would be a simple way to get SDI to OMT? I tested with OBS and that seems to be working with a bit of latency. Would love to get 4 SDI feeds with a Blackmagic Quad 2 card similar to Viz Connect Pro app. (Just not $995)
nikosman88
#2 Posted : Sunday, August 24, 2025 8:56:31 PM(UTC)
nikosman88
Greece
The most cheap solution is vmix basic hd 29 that accepts 4 inputs. Then you insert your 4 sdi inputs and enable cameras omt option and for 60$ you have 4 sdi to omt feeds in your lan and 1 output.
Guycochran
#3 Posted : Friday, August 29, 2025 2:41:32 PM(UTC)
Guycochran
The idea is that there would be a PC at the back of a venue that could take in 3-4 SDI cameras and send them over the network. To do it with vMix would be the $700 4K to get 4 Outputs.
Testing a bit of "Vibe coding" with ChatGPT to get something like this working well:
SDI to OMT Capture app
nikosman88
#4 Posted : Friday, August 29, 2025 9:28:23 PM(UTC)
nikosman88
Greece
You dont need 4 outputs version for 4 raw camera "outputs". As cameras/audio/calls can be output omt/ndi a clean feed indepedent per camera.
So the cheap version can give you clean camera feeds, even if the output pgm is limited to 1
WaltG12
#5 Posted : Saturday, August 30, 2025 3:33:04 AM(UTC)
WaltG12
To be clear, they're talking about this setting:
Though I'm not sure how much better it'd perform than OBS.
nikosman88
#6 Posted : Saturday, August 30, 2025 7:14:48 AM(UTC)
nikosman88
Greece
My personal opinion is that for decklink cards, vmix is better.
Also the omt plugin for obs need update in order to work like a filter also.
Ndi obs plugin has the filter "ndi dedicated output" so we can ndi out any source or camera. Omt I don't see this option so if we need to output 4 independent sdi sources, for now i don't see this option.
jet
#7 Posted : Friday, October 24, 2025 1:23:24 AM(UTC)
jet
Was thanked: 34 time(s) in 32 post(s)
"This content is no longer available."
