Joined: 2/7/2024(UTC) Posts: 187  Thanks: 12 times Was thanked: 7 time(s) in 6 post(s)
I had updated to the latest version, and started having daily crashes. So I rolled back to version .39, and just had another crash. Event viewer reporting .NET runtime error  image (12).png (55kb) downloaded 53 time(s).The other error reported:  image (13).png (127kb) downloaded 50 time(s).
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
This usually indicates either: 1. A hardware fault (especially if you have a Intel i7/i9 13xxx or 14xxx CPU) 2. Faulty VST3 plugins 3. Faulty NDI sources (see https://www.vmix.com/kno...lation-mode-feim-for-ndi to isolate) I would suggest reaching out to support and sending a Support Report from within vMix so we can diagnose further.
I can't be for sure that it was the new version, but after updating today, we had zero stability. Any camera, whether straight in or through ATEM dropped out and flashed a pinkish/brown screen. Tried every known working cable in the building. Uninstalled, found my old download of 27, then all was well.
That is caused by some program blocking vMix from installing all the files it needs. Make sure to close all programs and install vMix again to fix.
