knbPixels
#1 Posted : Thursday, August 21, 2025 12:10:30 AM(UTC)
knbPixels
I had updated to the latest version, and started having daily crashes. So I rolled back to version .39, and just had another crash. Event viewer reporting .NET runtime error
image (12).png (55kb) downloaded 53 time(s).
The other error reported:
image (13).png (127kb) downloaded 50 time(s).
#2 Posted : Thursday, August 21, 2025 12:49:34 AM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
This usually indicates either:
1. A hardware fault (especially if you have a Intel i7/i9 13xxx or 14xxx CPU)
2. Faulty VST3 plugins
3. Faulty NDI sources (see https://www.vmix.com/kno...lation-mode-feim-for-ndi to isolate)
I would suggest reaching out to support and sending a Support Report from within vMix so we can diagnose further.
jwells6
#3 Posted : Thursday, August 21, 2025 11:06:56 AM(UTC)
jwells6
I can't be for sure that it was the new version, but after updating today, we had zero stability. Any camera, whether straight in or through ATEM dropped out and flashed a pinkish/brown screen. Tried every known working cable in the building. Uninstalled, found my old download of 27, then all was well.
#4 Posted : Thursday, August 21, 2025 12:21:20 PM(UTC)
That is caused by some program blocking vMix from installing all the files it needs.
Make sure to close all programs and install vMix again to fix.
