Systems
Vmix worked on Win10 but does not on my new Win11 PC
I bought Vmix BASIC HD some years ago and it worked fine on my Win10 PC. Since I wanted to upgrade this PC to Win11 I made a system compatibilty test and found this PC was not compatible for Win11. So.. I had to buy a new system and mount Win11 on it. That worked well. I then went to my Vmix account and informed my account that I had installed my registered Vmix to a new PC. And that worked well too. I now have two Vmix registered versions installed (old Win10 & new Win11 PC). Fine.
My problem here is that when I click the X at the top right of the Vmix window to close the program I see the program reacts a little but the program does not shut off. I must go to the win Task manager and brutaly end the Vmix task the get it close.
I'm using Vmix BASIC HD ver 24.0.0.72 My PC has an Intel Ultra 7 CPU with 32 gigs of ram installed. Can you help ?
Originally Posted by: jpdesroc  I'm using Vmix BASIC HD ver 24.0.0.72 My PC has an Intel Ultra 7 CPU with 32 gigs of ram installed. Can you help ?
ver 24.0.0.72 ? Might consider updating. This version is too many years old !
Systems
