jpdesroc
#1 Posted : Wednesday, August 20, 2025 11:27:05 PM(UTC)
jpdesroc
I bought Vmix BASIC HD some years ago and it worked fine
on my Win10 PC. Since I wanted to upgrade this PC to Win11
I made a system compatibilty test and found this PC
was not compatible for Win11.
So.. I had to buy a new system and mount Win11 on it.
That worked well. I then went to my Vmix account
and informed my account that I had installed my registered Vmix
to a new PC. And that worked well too.
I now have two Vmix registered versions installed (old Win10 & new Win11 PC). Fine.
My problem here is that when I click the X at the top right
of the Vmix window to close the program I see the program
reacts a little but the program does not shut off.
I must go to the win Task manager and brutaly end the Vmix task
the get it close.
I'm using Vmix BASIC HD ver 24.0.0.72
My PC has an Intel Ultra 7 CPU with 32 gigs of ram installed.
Can you help ?
#2 Posted : Thursday, August 21, 2025 12:09:02 AM(UTC)
Can you help ?
ver 24.0.0.72 ?
Might consider updating. This version is too many years old !
