NDI
vMixDesktopCapture failed to install on Window 11
Joined: 1/11/2019(UTC) Posts: 6  Location: Sugar Land
When I tried to install vMixDesktopCapture on the new Window 11 laptop, I got this error:
The following feature couldn't be installed: .NET Framework 3.5 (includes .NET 2.0 and 3.0)
The changes couldn't be completed. Please reboot your computer and try again. Error code: 0x800F0922
When I clicked the link saying Tell me how to solve this problem, it leads me to open .NET Framework ... but my PC does not have that folder.
What can I do?
Joined: 4/23/2017(UTC) Posts: 1,468  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
You can install the latest .net manually and try the installer again.
mavik,
Thanks for helping, but I don't know how to install .NET 3.5. The instruction is to goto install directory to change something, but this is a brand new Windows 11 Pro laptop, and that directory was not there.
Could you provide specific steps?
Thank you very much.
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thank you very much. https://www.microsoft.co...nload/details.aspx?id=21
Doggy,
Thanks for your post.
My problem was failure to install .NET 3.5. When I tried to install vMix DesktopCapture, it tried to install .NET 3.5, and failed. I tried to manually install it just like you suggested, I got the same problem. The error I got was always:
************* The Following feature couldn't be installed:
.NET Framework 3.5 (include .NET 2.0 and 3.0)
The changes couldn't be completed. Please reboot your computer and try again. Error code 0x800F0922 **************
I looked up the solution for that error code, and could not follow what it tells me to do. The error code seems about Windows 10, but my PC is 11 PRO.
Thank you all for trying to help. The problem was corrupted files in Windows. After talking to the laptop maker, they suggested to reset the PC, and after it's done, I was able to install vMix DesktopCaptures.
NDI
