nikosman88
#1 Posted : Monday, August 18, 2025 11:53:03 PM(UTC)
nikosman88
Greece
Hi. Does the app work in windows 10? I install it,open it,select an omt source and press connect. It work for 1-2" and then drop a message and crash
Also you say no setup required,but when i run the .exe it opened setup installer
Follo
#2 Posted : Tuesday, August 19, 2025 7:29:49 PM(UTC)
Follo
Germany
Was thanked: 14 time(s) in 8 post(s)
I downloaded your first version 1.0.0.1 and just tried to download your latest Version.
But I just want to inform you that the latest Verion is blocked by Windows Defender (Trojan:Script/Sabsik.FL.A!ml).
Best regards.
Michel
thanks 1 user thanked Follo for this useful post.
Peter1000 on 8/19/2025(UTC)
Peter1000
#3 Posted : Tuesday, August 19, 2025 8:59:00 PM(UTC)
Peter1000
Switzerland
Was thanked: 85 time(s) in 65 post(s)
Sorry for the inconvenience! This should be due to my setup program, which uses an unusual compression method. When I google it, along with the entry Inno Setup, I find many descriptions of the alarm.
My Windows 11 system does not report any errors, but my Windows 10 system has deleted the setup program AFTER installation :-) Fortunately, the alarm allowed me to identify the cause, and I hope that it will now function properly.
I have now packed it without compression in InnoSetup and i had no more alarms. (Version 1.0.0.3, which also hides the cursor in fullscreen)
Follo
#4 Posted : Tuesday, August 19, 2025 9:15:20 PM(UTC)
Follo
Germany
Just downloaded the new version 1.0.0.3 and no virus alert. Tested it. It is working great in windowed mode, but in Fullscreen Playback the video stutters.
Thx for your quick response.
Luis70
#5 Posted : Tuesday, August 19, 2025 10:00:35 PM(UTC)
Luis70
Grenada
The first link is not working ... could you repost the link
Peter1000
#6 Posted : Tuesday, August 19, 2025 11:18:32 PM(UTC)
Peter1000
Switzerland
follow the link, this leads to the OMT page in our wiki, there is the download link
Peter1000
#7 Posted : Tuesday, August 19, 2025 11:36:05 PM(UTC)
Peter1000
Switzerland
What does your Task Manager say, CPU % ? Traffic wise there is no difference between windowed mode and fullscreen, only your computer has to draw it faster.
Could you tell us the specs of your computer?
Follo
#8 Posted : Tuesday, August 19, 2025 11:56:30 PM(UTC)
Follo
Germany
CPU % is at 3%. I have Ryzen 9 5950x and a Nvidia RTX 3090. Tested it with the OMTViewer from vMix in fullscreen, and that is working fine. Tried to download your version 1.0.0.4 but again Defender alert. Do you have a changelog to your versions?
Tested also with ver. 1.0.0.1 and also have stuttering during Fullscreen.
I also tested the Player on Legion Pro Laptop over Wifi and there it is even stuttering in windowed mode. Again, the vMix OMT Player from Github has no stuttering but of course no sound.
Both tested with an 1080P25P video file (Settings: Audio: Master; Alpha Channel: None; Resolution HD1080; OMT quality: Default). Hope it helps.
(Edit)
Tested it with OBS and the OMT Plugin and everything is working fine (Video & Audio, no Stuttering) even over Wifi.
Peter1000
#9 Posted : Wednesday, August 20, 2025 1:22:13 AM(UTC)
Peter1000
Switzerland
@Follo
Unfortunately i have no Ryzen Computers. I also tested it on all 5 PC's with Windows defender, downloading 1.003, 1004 odr both, no more alarm on several downloads.
I will put the code on github, tomorrow afternoon.
Peter1000
#10 Posted : Wednesday, August 20, 2025 11:42:43 PM(UTC)
Peter1000
Switzerland
I am closing this topic. After initially working wonderfully, I am now unable to get it to function with the current vMix versions.
Sorry
Soundfloss
#11 Posted : Wednesday, September 17, 2025 2:20:49 AM(UTC)
Soundfloss
Sorry
I guess this is where OBS uses OPEN SOURCE so people can contribute(in github) to help you make changes & try almost immediately to see it work.
