Beta Discussion
QuadView (fail to get the purpose)
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
The Replay QuadView with the option to hide the info and audio got me excited for our VAR project.
4 Cameras in standard I Can see them ALL as needed be it in Live or scrolling through Recorded, they all 4 respond (top right or bottom left qaurter)
But a bit if a shame as Cam 3 and 4 now freeze in Live Although they do allow synchronized scrolling through recorded though
I do understand/aware that 3 and 4 can not used for "editing" purposes but that is no issue
(tried all option variations)
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Actually in vMix Replay, by default A and B have always worked that way, it is only through a special checkbox (Show Live Sources when in A and B mode) that you can see the live sources, rather than recorded in those views.
So the purpose of the Quad View, is for review of recorded, being able to step through events seeing a high resolution feed of all four camera angles at once.
If you need to see a Quad View of the live cameras, then you can setup a simple input with layers to achieve that and use a shortcut to switch between that and the Replay MultiView if needed.
Martin vMix
Joined: 4/26/2025(UTC) Posts: 23   Location: São Paulo Was thanked: 8 time(s) in 3 post(s)
VAR Project? Interesting Originally Posted by: doggy  The Replay QuadView with the option to hide the info and audio got me excited for our VAR project.
Beta Discussion
