#1 Posted : Sunday, August 17, 2025 5:14:30 AM(UTC)
The Replay QuadView with the option to hide the info and audio got me excited for our VAR project.
4 Cameras in standard I Can see them ALL as needed be it in Live or scrolling through Recorded, they all 4 respond (top right or bottom left qaurter)
But a bit if a shame as Cam 3 and 4 now freeze in Live Although they do allow synchronized scrolling through recorded though
I do understand/aware that 3 and 4 can not used for "editing" purposes but that is no issue
(tried all option variations)
#2 Posted : Sunday, August 17, 2025 11:44:34 AM(UTC)
Actually in vMix Replay, by default A and B have always worked that way, it is only through a special checkbox (Show Live Sources when in A and B mode)
that you can see the live sources, rather than recorded in those views.
So the purpose of the Quad View, is for review of recorded, being able to step through events seeing a high resolution feed of all four camera angles at once.
If you need to see a Quad View of the live cameras, then you can setup a simple input with layers to achieve that and use a shortcut to switch between that
and the Replay MultiView if needed.
InstantReplayGO
#3 Posted : Sunday, August 17, 2025 12:09:40 PM(UTC)
InstantReplayGO
Brazil
Was thanked: 8 time(s) in 3 post(s)
VAR Project? Interesting
