daver89
#1 Posted : Saturday, August 16, 2025 4:24:38 AM(UTC)
daver89
Hi All,
I already have the JSON data set up and the data comes in fine.
I have also set up a Trigger "Action" in the Bit Focus Companion app to use a vMix input/title as an overlay on top of another input and it toggles the overlay on and off in vMix which is perfect.
But, additionally I would like that overlay to turn on when the data variable changes; so for example if the data variable on my title is 0:00 but then suddenly new data comes in to change that variable to 2:00 I want the overlay to be turned on when it changes.
I tried to use the "Event" tab to make a "When Variable Changes" event, but it asks me which variable I want it to watch for, and when I go to find the variables in the drop down list there aren't any that say JSON data and instead I can only choose the title itself and not the data I have assigned to it. There are several options for the title, including some of the following: "Full Title" "GUID" "Remaining ss:mm" etc etc. but none of those are working, when the data variable changes it doesn't trigger the overlay.
What am I missing here? Is there a "Condition" setting I am missing? I was reading online about JSON options under the internal tab of the Conditions dropdown but they are not showing up.
I basically want the overlay toggle to happen when the variable changes.
Can anyone help me with this?
nikosman88
#2 Posted : Saturday, August 16, 2025 9:54:07 PM(UTC)
nikosman88
Greece
Hi. Try to select the title input and text layer in which the json data comes in. For example like $(vmix:input_title1_layer_Message.Text_titletext) you can see your actual title name and layer in bitfocus variables-->vmix section
This for every time the value changes in whatever. If you need specific value you can use "on condition become true"-->internal -->operation = and you can write the value you need,when it is true to do the action
