Leif
#1 Posted : Wednesday, August 6, 2025 5:14:32 AM(UTC)
Leif
Sweden
Is there any way for vMix to send a VISCA command to set absolute coordinates?
It exists in the protocol, but is there any way to channel it through a vMix script?
EDIT:
I thought I could work around the whole thing by writing my own program to handle the PTZ control — and it works.
But I also want to use vMix’s fantastic integration, yet we can’t have two connections to the camera.
So I figured I’d relay vMix’s control through my program on (127.0.0.1) localhost, but then I’d need to set a port number, which vMix doesn’t support.
So I’m back to square one :-)
mavik
#2 Posted : Wednesday, August 6, 2025 9:19:08 PM(UTC)
mavik
Was thanked: 196 time(s) in 176 post(s)
You can integrate your script into vMix. Or call the script from vMix.
You could also try "Sony visca over IP" from the PTZ control. It works even with none sony cameras but not with all.
Leif
#3 Posted : Wednesday, August 6, 2025 11:27:32 PM(UTC)
Leif
Sweden
The problem is that the vMix Script engine only supports a selection of Visca commands.
The command I want to use does not seem to be supported in vMix.
knbPixels
#4 Posted : Thursday, August 7, 2025 3:43:25 AM(UTC)
knbPixels
Just out of curiosity, does the camera not support presets? That's essentially the same thing, just the coordinates are baked into the preset that you recall to
Leif
#5 Posted : Thursday, August 7, 2025 7:04:30 AM(UTC)
Leif
Sweden
Glad you asked! vMix has excellent support for PTZ, but not all the way.
vMix is designed to work with a joystick, sending a command to the camera indicating which direction it should move, and then a stop command when the joystick is released.
However, VISCA over IP supports a few additional commands, including the ability to send absolute position coordinates. By using the Stream Deck Plus, which features four rotary encoders, I can increase or decrease a value in my software to control the camera position.
This allows for very precise adjustments to the camera's position.
Since the camera only allows one IP connection at a time, I need to relay the control commands through vMix in order to make this function work.
So I still intend to use presets in vMix, but I get a much better sense of control by adjusting the camera’s position using the rotary dials instead of a joystick.
Turning the knobs gives me a more precise and tactile feel when fine-tuning the camera's pan, tilt, and zoom — something that's harder to achieve with a joystick alone.
knbPixels
#6 Posted : Monday, August 11, 2025 8:39:27 PM(UTC)
knbPixels
Could you not still accomplish the same thing using Companion's visca module to send movement commands? I used to do that a fair amount and it worked fine. In other words, Companion tells the camera to move left x amount every time you turn the encoder left by one tick, as opposed to using coordinates.
knbPixels
#7 Posted : Monday, August 11, 2025 8:42:43 PM(UTC)
knbPixels
Could you not still accomplish the same thing using Companion's visca module to send movement commands? I used to do that a fair amount and it worked fine. In other words, Companion tells the camera to move left x amount every time you turn the encoder left by one tick, as opposed to using coordinates. To gain back the ability to change how quickly the camera moves, you could either use variables as the value and change those variables with a knob or buttons, or you could also create a few different pages, like a fast, medium, and slow page, where each page uses different speeds for the camera control
Similar Topics
Sony VISCA over IP (General Discussion)
by Seriousfun 1/5/2024 11:08:05 AM(UTC)
Wanted: Sony Visca over IP exposure/WB controller tool (3rd Party Software and Development)
by JW 12/9/2022 5:08:27 AM(UTC)
Lumens VCA 50P no PTZ control using VISCA over IP (Hardware Compatibility)
by ckvideo 10/28/2022 12:01:30 AM(UTC)
Can't connect to VISCA over IP today, worked previously (General Discussion)
by JonHall.conp 9/14/2022 3:58:10 AM(UTC)
generic PTZ VISCA OVER IP [FR] (NDI)
by moriern 1/29/2021 10:24:23 AM(UTC)
Birddog P4K, VISCA over IP, and vMix (General Discussion)
by jakegilliam 8/9/2020 8:22:17 AM(UTC)
How to use Visca over IP in a script? (General Discussion)
by Ronald555 9/4/2019 4:17:57 AM(UTC)
Allow specifiying port in Sony VISCA over IP (PTZ settings) (Feature Requests)
by paperjet 4/19/2019 12:29:10 PM(UTC)
