Stinger transition and Audio Cross Fade
Hello, I'm currently trying to set up a Stinger 1 transition in a particular way.
I've successfully set up Stinger 1 transition to play an animation with an audio layer switching between Inputs 1 and 2. Inputs 1 and 2 are pre-recorded video files. Stinger 1's visual component is made with a GTzip file from GT Designer using an image sequence. Stinger 1's audio component is layered to the visual component. Stinger 1 is 2.4 seconds long. What I've been having trouble doing is setting up an audio cross fade between Input 1 and Input 2 during the transition. No matter what trigger delay settings I do, the cross fade only happens at the end of the transition, and I would like it to happen in the middle of the transition. The intention is to also have the audio from Stinger 1 overlap that cross fade. Is this possible?
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Originally Posted by: RMMedia  Hello, I'm currently trying to set up a Stinger 1 transition in a particular way.
I would de-couple the audio from the video files and use triggers to control it playing and the delay on the audio file.
