bulent_atlas
#1 Posted : Thursday, June 26, 2025 11:11:42 PM(UTC)
bulent_atlas
Turkey
I need to prepare a lower-third (KJ) package.
In the sample visual, first names are in regular font, while last names are in bold, and they are written together without a space. I also need to add the position (role) information afterward.
Is there a way to do this using Title Designer? 007_SP_FF_Line_Up_Example.jpg (695kb) downloaded 143 time(s).
#2 Posted : Friday, June 27, 2025 1:59:01 AM(UTC)
Originally Posted by: bulent_atlas Go to Quoted Post
Nope , not possible
Also A Search
bulent_atlas on 6/27/2025(UTC)
bulent_atlas
#3 Posted : Friday, June 27, 2025 2:07:53 AM(UTC)
bulent_atlas
Turkey
Nope , not possible
Also A Search
I believe our admin might consider this and, if not now, possibly provide a solution in future versions.
In international events, we can’t work with our own custom graphic packages — we have to follow the guidelines provided in the official booklets.
These graphics are also not designed with vMix in mind. They usually come as folders containing thousands of TGA files.
Right now, I’m trying to convert them all to PNG. Thankfully, Photoshop scripts helped me speed up the process.
semenov_nick_1990
#4 Posted : Monday, July 14, 2025 8:13:33 PM(UTC)
semenov_nick_1990
All you need is xaml.
Add Grid with columns
<UserControl x:Class="Mytitle"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mtl="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary"
mc:Ignorable="d" Width="1920" Height="1080">
<Grid x:Name="grd_Container">
<Grid x:Name="grd_TextContainer" HorizontalAlignment="Left" Margin="173,730,0,0" VerticalAlignment="Top" Background="#FF394C56" RenderTransformOrigin="0.5,0.5">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="Auto"/>
</Grid.ColumnDefinitions>
<TextBlock x:Name="txt_Name" Grid.Column="0" HorizontalAlignment="Center" TextWrapping="Wrap" Text="Sebastian" VerticalAlignment="Center" Foreground="White" FontSize="30" Margin="5,5,5,5" />
<TextBlock x:Name="txt_Surname" Grid.Column="1" HorizontalAlignment="Center" TextWrapping="Wrap" Text="PERERO" VerticalAlignment="Center" Foreground="White" FontSize="30" FontWeight="Bold" Margin="5,5,5,5" />
<TextBlock x:Name="txt_Roles" Grid.Column="2" HorizontalAlignment="Center" TextWrapping="Wrap" Text="(Pirat)" VerticalAlignment="Center" Foreground="White" FontSize="30" Margin="5,5,5,5" />
</Grid>
</Grid>
</UserControl>
But you should capitalize Surname manually (in XAML it is not simple to automate it)
