GT
"How can I do this through the Title Designer program?"
Joined: 10/21/2022(UTC) Posts: 24   Location: ankara Thanks: 16 times Was thanked: 4 time(s) in 3 post(s)
Hello, I need to prepare a lower-third (KJ) package. In the sample visual, first names are in regular font, while last names are in bold, and they are written together without a space. I also need to add the position (role) information afterward. Is there a way to do this using Title Designer?  007_SP_FF_Line_Up_Example.jpg (695kb) downloaded 143 time(s).
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: bulent_atlas  Hello, I need to prepare a lower-third (KJ) package. In the sample visual, first names are in regular font, while last names are in bold, and they are written together without a space. I also need to add the position (role) information afterward. Is there a way to do this using Title Designer? Nope , not possible Also A Search
Originally Posted by: doggy  Originally Posted by: bulent_atlas  Hello, I need to prepare a lower-third (KJ) package. In the sample visual, first names are in regular font, while last names are in bold, and they are written together without a space. I also need to add the position (role) information afterward. Is there a way to do this using Title Designer? Nope , not possible Also A Search I believe our admin might consider this and, if not now, possibly provide a solution in future versions. In international events, we can’t work with our own custom graphic packages — we have to follow the guidelines provided in the official booklets. These graphics are also not designed with vMix in mind. They usually come as folders containing thousands of TGA files. Right now, I’m trying to convert them all to PNG. Thankfully, Photoshop scripts helped me speed up the process.
All you need is xaml.
Add Grid with columns
<UserControl x:Class="Mytitle" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mtl="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary" mc:Ignorable="d" Width="1920" Height="1080"> <Grid x:Name="grd_Container"> <Grid x:Name="grd_TextContainer" HorizontalAlignment="Left" Margin="173,730,0,0" VerticalAlignment="Top" Background="#FF394C56" RenderTransformOrigin="0.5,0.5"> <Grid.ColumnDefinitions> <ColumnDefinition Width="Auto"/> <ColumnDefinition Width="Auto"/> <ColumnDefinition Width="Auto"/> </Grid.ColumnDefinitions> <TextBlock x:Name="txt_Name" Grid.Column="0" HorizontalAlignment="Center" TextWrapping="Wrap" Text="Sebastian" VerticalAlignment="Center" Foreground="White" FontSize="30" Margin="5,5,5,5" /> <TextBlock x:Name="txt_Surname" Grid.Column="1" HorizontalAlignment="Center" TextWrapping="Wrap" Text="PERERO" VerticalAlignment="Center" Foreground="White" FontSize="30" FontWeight="Bold" Margin="5,5,5,5" /> <TextBlock x:Name="txt_Roles" Grid.Column="2" HorizontalAlignment="Center" TextWrapping="Wrap" Text="(Pirat)" VerticalAlignment="Center" Foreground="White" FontSize="30" Margin="5,5,5,5" /> </Grid> </Grid> </UserControl>
But you should capitalize Surname manually (in XAML it is not simple to automate it)
GT
