Hi As I often do Livestreams to at least 2 different chanels at the same time, where i have to put different logos in the top corner of my stream, i have only 2 overlay-chanels to "work" with... I would very much apreaciate if the number would at least go up to 6 chanels! best regards
Joined: 12/27/2012(UTC) Posts: 5,515  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: JoKo  Hi As I often do Livestreams to at least 2 different chanels at the same time, where i have to put different logos in the top corner of my stream, i have only 2 overlay-chanels to "work" with... I would very much apreaciate if the number would at least go up to 6 chanels! best regards can easely add layers on inputs instead , turn them on/off through shortcuts, and even specify which overlays to use in the outputs. I'v managed 2 completly different sportfields streams each with their own data and graphics on a single machine (if you dont want/can use 2). Just takes a bit of planning and thinking outside of the box :-)
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
Add your Output as an Input and then add the corresponding logo on a layer. You can then set f.e. Input 10 as Output 2 and Input 11 as Output 3 and use this as the signal for your streaming-destinations.
Originally Posted by: fenki86  Add your Output as an Input and then add the corresponding logo on a layer. You can then set f.e. Input 10 as Output 2 and Input 11 as Output 3 and use this as the signal for your streaming-destinations. This does not work for me, as I allready have all 4 ouputs set up for different uses... (1 is the "normal" stream, 2 is a Videowall with diferent content, 3 is a cleanfeed for an external recorder an 4 is a "semi-cleen"feed with only some of the overlays for delivering to public broadcast via srt where i have to put the other logo on... so i have no output left to "double" the semiclean stream to put a different logo on
Originally Posted by: doggy  Originally Posted by: JoKo  Hi As I often do Livestreams to at least 2 different chanels at the same time, where i have to put different logos in the top corner of my stream, i have only 2 overlay-chanels to "work" with... I would very much apreaciate if the number would at least go up to 6 chanels! best regards can easely add layers on inputs instead , turn them on/off through shortcuts, and even specify which overlays to use in the outputs. I'v managed 2 completly different sportfields streams each with their own data and graphics on a single machine (if you dont want/can use 2). Just takes a bit of planning and thinking outside of the box :-) that is what i do at the moment, but it s not very flexible as i have something like 50 inputs and in total around 10 overlays i use on different situations...
