JoKo
#1 Posted : Thursday, July 10, 2025 12:37:54 AM(UTC)
JoKo
Germany
Hi
As I often do Livestreams to at least 2 different chanels at the same time, where i have to put different logos in the top corner of my stream, i have only 2 overlay-chanels to "work" with... I would very much apreaciate if the number would at least go up to 6 chanels!
best regards
#2 Posted : Thursday, July 10, 2025 3:47:52 AM(UTC)
Originally Posted by: JoKo Go to Quoted Post
Hi
best regards
can easely add layers on inputs instead , turn them on/off through shortcuts, and even specify which overlays to use in the outputs.
I'v managed 2 completly different sportfields streams each with their own data and graphics on a single machine (if you dont want/can use 2). Just takes a bit of planning and thinking outside of the box :-)
fenki86
#3 Posted : Thursday, July 10, 2025 6:00:48 PM(UTC)
fenki86
Add your Output as an Input and then add the corresponding logo on a layer. You can then set f.e. Input 10 as Output 2 and Input 11 as Output 3 and use this as the signal for your streaming-destinations.
JoKo
#4 Posted : Thursday, July 10, 2025 6:40:34 PM(UTC)
JoKo
Germany
This does not work for me, as I allready have all 4 ouputs set up for different uses...
(1 is the "normal" stream, 2 is a Videowall with diferent content, 3 is a cleanfeed for an external recorder an 4 is a "semi-cleen"feed with only some of the overlays for delivering to public broadcast via srt where i have to put the other logo on... so i have no output left to "double" the semiclean stream to put a different logo on
JoKo
#5 Posted : Thursday, July 10, 2025 6:44:06 PM(UTC)
JoKo
Germany
Hi
best regards
that is what i do at the moment, but it s not very flexible as i have something like 50 inputs and in total around 10 overlays i use on different situations...
