Joined: 7/10/2025(UTC) Posts: 2  Location: Toronto Thanks: 1 times
Hello all,
Long time vMix user - first time poster =)
Ive purchased a P8 Lenovo desktop thats running an NVIDIA RTX 5000 Ada video card - i was hoping this GPU was enough horsepower to run my mixes as i run a lot of overlays, PiP, video playback and NDI inputs. Running it for the fist time this week and im looking at +50% on the GPU Mem.. any thoughts as to why this consumption is so great?
Appreciate any input y'all have to share!
vMix report EX FPS: 30 Render Time: ~10ms (avg) GPU Mem: 50%-57% (avg) CPU Mem: 1% CPU vMix: 1% Total: 2%
Computer spec Lenovo P8 AMD Ryzen Threadripper PRO 128GB RAM 2TB Storage NVIDIA RTX 5000 Ada
Task Manger Process vmix 1.5% CPU 800MB Memory
Joined: 7/1/2020(UTC) Posts: 105  Location: Earth Was thanked: 23 time(s) in 20 post(s)
are you using resizable bar? if so ignore this number and carry on. also check in vmix performance settings to make sure you are using the nvidia, and not the onboard gpu.
 1 user thanked AudioGreg for this useful post.
Thanks AudioGreg =)
the system was set to the nvidia card - but i selected High Input Performace mode and it dropped the GPU Mem to ~14% Ill give it the gears later this afternoon to see how it behaves.
Joined: 9/10/2015(UTC) Posts: 139  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
With ResizableBAR you actually don't want high input performance mode.
That option uses an extra layer of memory swaps on GPU memory to increase throughout but at the cost of added latency. Prior to ReBAR your CPU could only write to 128MB of memory at a time. The GPU memory usage percentage you see on the status bar _always_ assumes you only have 128MB, even if you have a larger BAR (the amount of memory you can write to).
Say you resized your BAR to 1GB. In that case you'd want to take advantage of all that available memory so you'd expect yout GPU memory usage to be above 100%.
Vmix 28 show correctly when rebar is enabled. So you will see 100% when really gpu memory is full by 100%
