offroadmediagroup
#1 Posted : Tuesday, April 1, 2025 1:33:36 PM(UTC)
offroadmediagroup
SRT Input settings are not exposed to the API. We need the ability to change SRT Input settings on the fly. Use cases include changing submix sources where there are dedicated outputs etc, replay sources, etc. It is more efficient in large input arrays to put them in an external multiview and only have vMix ingesting the required sources.
thanks 1 user thanked offroadmediagroup for this useful post.
TL68 on 7/9/2025(UTC)
TL68
#2 Posted : Wednesday, July 9, 2025 11:01:07 PM(UTC)
TL68
Sweden
Hi!
I support this feature request! And would also like to add functionality to populate the fields in the SRT input from a datasource. Usecase for this is to build SRT input choice menu in for example Google Sheets which then via data source in vmix is used to change IP, Port, Latency etc in the SRT input. This so we easily can change SRT streams into vMix without having multiple inputs for each possible SRT feed (we have around 60 possible SRT sources which we would like to use in this way).
I hope this can be implemented in future developement.
