Feature Requests
Expose SRT Inputs changes to API
Joined: 9/7/2024(UTC) Posts: 39  Location: The Great PNW Was thanked: 5 time(s) in 5 post(s)
SRT Input settings are not exposed to the API. We need the ability to change SRT Input settings on the fly. Use cases include changing submix sources where there are dedicated outputs etc, replay sources, etc. It is more efficient in large input arrays to put them in an external multiview and only have vMix ingesting the required sources.
 1 user thanked offroadmediagroup for this useful post.
Joined: 12/8/2022(UTC) Posts: 162  Thanks: 48 times Was thanked: 3 time(s) in 3 post(s)
Hi! I support this feature request! And would also like to add functionality to populate the fields in the SRT input from a datasource. Usecase for this is to build SRT input choice menu in for example Google Sheets which then via data source in vmix is used to change IP, Port, Latency etc in the SRT input. This so we easily can change SRT streams into vMix without having multiple inputs for each possible SRT feed (we have around 60 possible SRT sources which we would like to use in this way). I hope this can be implemented in future developement.
Feature Requests
