Hi, we and i hope others as well, frequently use titles which has a not so user friendly setting window.  vmix-title-gui.png (41kb) downloaded 63 time(s). At the middle there is a huge empty space which is so useless because titles are usually 1-2 row long. So please let it resizing by the users at the middle of the window. To see less from the empty space and more from the list. I also suggest to be able reordering the list by drag and drop. If you add new line it always takes place at the end of the list. Which is often not a logical order. Thank you! We at livebroadcast.hu are great funs of vMix and we use it very often to ours live stream projects. We appreciate every improvements!
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: marton  Hi At the middle there is a huge empty space which is so useless because titles are usually 1-2 row long. So please let it resizing by the users at the middle of the window. To see less from the empty space and more from the list.
Not useless for everyone or use datasources, much easier
Joined: 4/23/2017(UTC) Posts: 1,480  Location: Germany Thanks: 3 times Was thanked: 194 time(s) in 174 post(s)
I highly recommend creating a csv file with your entries. Then import the csv as a datasource and link the datasource with the title. I use same approach for 150+ titles and it works 100%, easy, editable, etc.
