marton
#1 Posted : Friday, July 4, 2025 10:52:19 PM(UTC)
marton
we and i hope others as well, frequently use titles which has a not so user friendly setting window.
At the middle there is a huge empty space which is so useless because titles are usually 1-2 row long. So please let it resizing by the users at the middle of the window. To see less from the empty space and more from the list.
I also suggest to be able reordering the list by drag and drop. If you add new line it always takes place at the end of the list. Which is often not a logical order.
Thank you!
We at livebroadcast.hu are great funs of vMix and we use it very often to ours live stream projects. We appreciate every improvements!
#2 Posted : Friday, July 4, 2025 11:51:33 PM(UTC)
Originally Posted by: marton Go to Quoted Post
Hi
Not useless for everyone or use datasources, much easier
mavik
#3 Posted : Monday, July 7, 2025 6:52:35 PM(UTC)
mavik
I highly recommend creating a csv file with your entries. Then import the csv as a datasource and link the datasource with the title. I use same approach for 150+ titles and it works 100%, easy, editable, etc.
