bholland
#1 Posted : Sunday, June 29, 2025 11:30:09 PM(UTC)
bholland
Views messages in topic : 5
I will be reaching out to ProPresenter support as well, but wanted to ask if anyone else has experienced this issue.
I recently replaced the Mac at my church with a new M4 model. I reinstalled ProPresenter 7 and migrated the database. I rebuilt the two NDI outputs that I use with vMix. All of that works fine.
However, every Sunday morning I notice that the NDI inputs in vMix will not connect. I always make sure that ProPresenter is up and running before I open vMix. Fortunately, all I have to do is edit the input, click "Change", choose the NDI output again and save the changes to that input. This happens every time and I do not touch the NDI output settings in ProPresenter.
Has anyone experienced this? I set an IP reservation on the Mac so that it would keep the same IP, yet this is still happening. It's almost like ProPresenter is somehow sending these NDI outputs a different way every time it opens. I've even seen this happen if during service ProPresenter has to be closed and then re-opened. I have to edit the NDI inputs in vMix again, click change, and choose the correct output.
Thank you for your advice. I will continue to troubleshoot on my end as well.
Just a FYI: this issue did not happen with the old Mac before this one.
mavik
#2 Posted : Sunday, June 29, 2025 11:45:23 PM(UTC)
mavik
Does it also come back when you right click in that input and select the same NDI source again.
bholland
#3 Posted : Sunday, June 29, 2025 11:52:26 PM(UTC)
bholland
Yes it does. That's when I edit the input, click change, and choose the same NDI output (with the same name and number).
I have also reached out to Propresenter support to see what they say.
mavik
#4 Posted : Sunday, June 29, 2025 11:55:31 PM(UTC)
mavik
I mean w/o the change. Just on the input small preview, right click and select one of the available NDI feeds.
bholland
#5 Posted : Monday, June 30, 2025 12:03:11 AM(UTC)
bholland
I have to click change on the input otherwise it's black. These are the only two NDI inputs I'm using.
bholland
#6 Posted : Monday, June 30, 2025 3:06:22 AM(UTC)
bholland
Propresenter support recommended that I install the NDI tools on the Mac. So far that seems to have solved the issue. I will know more next week.
