Kyrin
#1 Posted : Wednesday, May 14, 2025 4:16:05 AM(UTC)
Kyrin
Canada
Windows 11, 24H2 Build 26100.3775
vMix 4K - 28.0.0.41 x64
Intel Core i9-13900K, 32GB RAM
GeForce RTX 4070 Ti, ReBAR enabled
I sent in a support report, but I don't know what email is tied to the support key (ends in XGCK) as I'm helping a friend with this.
Basically I get two lines in Event viewer when vMix randomly crashes... sometimes when live, sometimes when nobody is even using the computer and it's just idle after having been live with no issues for over 20 hours... First is an event 1026 from .NET Runtime:
Application: vMix64.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address 00007FF89B4BBAF7
Then an event 1000 Application error from vMix:
Faulting application name: vMix64.exe, version: 28.0.0.41, time stamp: 0x680a57d3
Faulting module name: ntdll.dll, version: 10.0.26100.3775, time stamp: 0x5e4be250
Exception code: 0xc0000005
Fault offset: 0x000000000001baf7
Faulting process id: 0x10EF8
Faulting application start time: 0x1DBC0A442EAFE31
Faulting application path: C:\Program Files (x86)\vMix\vMix64.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: 50879477-b373-4477-92ac-63d41bf76a02
Faulting package full name:
Faulting package-relative application ID:
mavik
#2 Posted : Wednesday, May 14, 2025 4:41:03 AM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
Sounds to me like a .net issue. Maybe uninstall and reinstall the latest .net. But it is more guessing I have to admit.
nikosman88
#3 Posted : Wednesday, May 14, 2025 4:54:44 AM(UTC)
nikosman88
Greece
Hi. See also this https://forums.vmix.com/...Crashing-Issue---avcodec you have cpu 13x known issue to die after some time
sinc747
#4 Posted : Saturday, May 17, 2025 3:30:15 PM(UTC)
sinc747
Yep. Sounds like a failing Intel CPU. Contract Intel tech support. They are very responsive.
- Tom
TEPgav
#5 Posted : Saturday, June 21, 2025 7:04:07 PM(UTC)
TEPgav
Ireland
Have been having the same issues. Server solid for years and suddenly BSOD since May. First I found it related to NIC driver. Since addressing this, the crashes continue but the WFP (windows filtering platform)
Have since discovered that workstation computers are have lots of issues with windows build 26100 and widespread reports of crashes.
I had zero hardware, software changes to our server, it has one role, VMix production. Instability started with this windows version.
We plan a roll back to 23h2 today to hopefully gain back stability.
Maybe this might point to your issue too?
