vMix system been solid for well over a year, suddenly getting crashes
Windows 11, 24H2 Build 26100.3775 vMix 4K - 28.0.0.41 x64 Intel Core i9-13900K, 32GB RAM GeForce RTX 4070 Ti, ReBAR enabled I sent in a support report, but I don't know what email is tied to the support key (ends in XGCK) as I'm helping a friend with this. Basically I get two lines in Event viewer when vMix randomly crashes... sometimes when live, sometimes when nobody is even using the computer and it's just idle after having been live with no issues for over 20 hours... First is an event 1026 from .NET Runtime: Application: vMix64.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: exception code c0000005, exception address 00007FF89B4BBAF7
Then an event 1000 Application error from vMix: Faulting application name: vMix64.exe, version: 28.0.0.41, time stamp: 0x680a57d3 Faulting module name: ntdll.dll, version: 10.0.26100.3775, time stamp: 0x5e4be250 Exception code: 0xc0000005 Fault offset: 0x000000000001baf7 Faulting process id: 0x10EF8 Faulting application start time: 0x1DBC0A442EAFE31 Faulting application path: C:\Program Files (x86)\vMix\vMix64.exe Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll Report Id: 50879477-b373-4477-92ac-63d41bf76a02 Faulting package full name: Faulting package-relative application ID:
Sounds to me like a .net issue. Maybe uninstall and reinstall the latest .net. But it is more guessing I have to admit.
Yep. Sounds like a failing Intel CPU. Contract Intel tech support. They are very responsive.
- Tom
Joined: 2/28/2024(UTC) Posts: 7  Location: Dublin Thanks: 1 times
Have been having the same issues. Server solid for years and suddenly BSOD since May. First I found it related to NIC driver. Since addressing this, the crashes continue but the WFP (windows filtering platform) Have since discovered that workstation computers are have lots of issues with windows build 26100 and widespread reports of crashes. I had zero hardware, software changes to our server, it has one role, VMix production. Instability started with this windows version.
We plan a roll back to 23h2 today to hopefully gain back stability.
Maybe this might point to your issue too?
