Cyril81
#1 Posted : Wednesday, June 4, 2025 5:12:41 PM(UTC)
Cyril81
Bonjour à tous,
Is it possible to keep the same input in the preview window whatever you switch in the output ?
Thank you.
vmixgreg
#2 Posted : Wednesday, June 4, 2025 8:13:08 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Use the "CutDirect" Shortcut.
vMixGreg
nikosman88
#3 Posted : Wednesday, June 4, 2025 8:13:35 PM(UTC)
nikosman88
Greece
Hi.
Yes if you do transition by using cutdirect (you have to create it by shortcut) then it will change to pgm without affect preview
Cyril81
#4 Posted : Wednesday, June 4, 2025 8:50:15 PM(UTC)
Cyril81
Hahaaaaa Yes !
Thank you guys !
