Keeping the same input in the pvw ?
Bonjour à tous, Is it possible to keep the same input in the preview window whatever you switch in the output ? Thank you.
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 64 Location: Canada
Thanks: 1 times Was thanked: 20 time(s) in 19 post(s)
Use the "CutDirect" Shortcut.
vMixGreg
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 99 time(s) in 95 post(s)
Hi. Yes if you do transition by using cutdirect (you have to create it by shortcut) then it will change to pgm without affect preview
Hahaaaaa Yes ! Thank you guys !
