Joined: 6/1/2025(UTC) Posts: 2  Location: Sydney Thanks: 1 times
when this error occurs api stop getting new command until we click it ok is there any way to suppress or bypass it ?
Joined: 12/27/2012(UTC) Posts: 5,393  Location: Belgium Thanks: 300 times Was thanked: 990 time(s) in 822 post(s)
Originally Posted by: RossCarter  when this error occurs api stop getting new command until we click it ok is there any way to suppress or bypass it ? By writing the api command correctly maybe show what you are intending to accomplish/do to get more help
its not a single command i add some items into vmix playing list then garbage collect pre used itemms i guess it refers to a removed object by gc i got an external sol to close opened error window by vb.net but i guess there is an internal sol to resolve this and app continue func . tnx by the way
Originally Posted by: RossCarter  its not a single command i add some items into vmix playing list then garbage collect pre used itemms i guess it refers to a removed object by gc i got an external sol to close opened error window by vb.net but i guess there is an internal sol to resolve this and app continue func . tnx by the way English ?
Joined: 12/24/2021(UTC) Posts: 674  Location: athens Thanks: 158 times Was thanked: 85 time(s) in 81 post(s)
Originally Posted by: RossCarter  its not a single command i add some items into vmix playing list then garbage collect pre used itemms i guess it refers to a removed object by gc i got an external sol to close opened error window by vb.net but i guess there is an internal sol to resolve this and app continue func . tnx by the way Hi. Can you select how slow or fast you remove the items? If yes,try to remove files in a bigger time amount. I see some times this error while im using vscheduler for vmix in order to play 24/7 content. If i send too much times in a small amount of time an item to be play,then this message may appear. I didnt find/search a way to auto-bypass this message.
