Beau Dodson
#1 Posted : Wednesday, May 28, 2025 12:55:02 AM(UTC)
Beau Dodson
Is there software available that allows me to draw on the screen at all times? I don't want to use the Telestrator, because I can only do that on one screen image at a time, and it does not allow me to zoom in and out on that screen. I am using it for weather radar.
I want something that allows me to draw on the screen at all times. Even when switching between scenes. Basically, it would always be on top. Like my mouse icon.
I hope that makes sense.
Thank you for your help.
nikosman88
#2 Posted : Wednesday, May 28, 2025 6:27:35 PM(UTC)
nikosman88
Greece
Hi. Possible workaround -->open an app like mspaint or like this that is for drawing. Then take this app inside vmix using ndi/desktop capture and chroma/colour key it.Then whatever you do in this app it will be inside vmix and you can overlay it as you like.
