reassigning inputs to 2 box multiviewer
Joined: 3/10/2025(UTC) Posts: 17   Location: Loughborough
I've had a look through the post concercerning this topic from about 4 years agao and wondered what might have changed in vMix to make this easier.
This transition and combination of transitions woould be automated using Tinkerlist Cuez to make the transitions in a live news rundown. The automation efffectively would work like button pushes say from a stream deck.
I have 3 studio camera positions and 3 OB camera remotes. I have created a simple two box using presenter 1 camera position input and OB 1 remote input over a graphics background. It uses a merge transition to go from the full screen pres 1 shot to the two way box. i can then cut between thje OB feed and the studio feed full frame going back to the 2 box for the final goodbye and transitioning the merge back to full screen presenter.
Given I have 9 combinations of the 3 presenters and 3 OB feeds I could create the 9 seperate composites in vMix and call the one I need in at the time using the automation. This feels very clumsy and I was hoping I could create one two box template and dynamically change the inputs on the studio and OB feed side independently depending on what studio and OB sources I need at any one time.
Any thoughts would be appreciated.
Michael
Hi. Something like this? it can also be done more complex with scripting,or other tools like companion and using triggers like "when this in that layer,put that in this layer" etc
Thanks for the info - not had time to go thropugh your post yet - on my list for next week
You can also go with some dynamics in the layouts. I took this video as inspiration and not only change the layout also use dynamic inputs for the sources. This way it's super flexible. I combine it with a streamdeck plus and use the knobs to select the layout, and another one to select the input number. Full flexibility with just two knobs.
