6 Pages«<456
Pavel
#101 Posted : Thursday, December 23, 2021 6:55:49 PM(UTC)
Pavel
Hello everyone
I'm excited as it works great.
Thank you very very much.
I have one request. It would be great if it was in the web interface to change background colors and text.
mgrayeb
#102 Posted : Sunday, May 8, 2022 11:09:48 AM(UTC)
mgrayeb
Hi. I've gotten up to the point where the code is finished uploading but it seems to be stuck on "Hard resetting via RTS Pin" and the device does not reboot. Any suggestions? I've tried with three separate M5Stack ATOM Matrix units; all with the same result. Thank you.
mgrayeb
#103 Posted : Monday, May 16, 2022 2:04:36 AM(UTC)
mgrayeb
Using the M5StickC, I've gotten it to work -- it's great!!! The only thing I'm experiencing is that when I close vMix and then re-open it (as the volunteers will be doing in the church each week) that the tally lights won't automatically reconnect. I need to log into the web interface for each M5StickC and click the "Reconnect to vMix" button at the bottom of the web interface.
Am I doing something wrong? Should the reconnect be happening automatically?
And is there a way to establish static IPs for the M5Stick5s or are they only DHCP?
Thanks.
Lennart
#104 Posted : Monday, May 16, 2022 5:01:09 AM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
Thanks.
I would suggest setting up reserved IPs for each M5 stick so that they always get the same IP. You should be able to do this in your router usually under LAN setup.
Then I'd save a bookmark for each M5 and tell your volunteers to press reconnect on each.
I hope that helps :)
thanks 1 user thanked Lennart for this useful post.
mgrayeb on 5/16/2022(UTC)
guidogast
#105 Posted : Monday, May 16, 2022 6:20:39 PM(UTC)
guidogast
Netherlands
Was thanked: 36 time(s) in 24 post(s)
Thanks.
Both questions you ask are possible and are described in the readme file on the Github page under "Reconnect Interval" and "Static IP Address". Hope this helps.
thanks 1 user thanked guidogast for this useful post.
mgrayeb
#106 Posted : Monday, May 16, 2022 7:38:26 PM(UTC)
mgrayeb
Thank you. I didn't realize I needed to change the time interval for reconnect attempts from zero to some other number. Much appreciated.
UzumyLemon
#107 Posted : Wednesday, June 1, 2022 3:24:11 AM(UTC)
UzumyLemon
Brazil
Originally Posted by: guidogast Go to Quoted Post
Do you want an affordable tally light for your camera, without having to solder yourself? The M5Stick-C by M5Stack comes to the rescue!
For the last week I've been working on this, it is not completely finished yet, but I will not stop until it is really user friendly. Once the project is done, I will upload a comprehensive video tutorial on how to set it up if you've never worked with microcontrollers before. (Including a first time install of the Arduino IDE, since you will have to flash the code to the stick yourself)
You can find my project here: https://github.com/guido-visser/vMix-M5Stick-Tally-Light
An example in GIF form:
Tally Light Example
Please feel free to submit feature requests (please do so on the GitHub page (as an issue), so that everything is in one place). If I think the feature will be a valuable to the project, I will consider implementing it.
If you're having problems, please submit an issue on the GitHub page.
I've made an in-depth tutorial on how to flash the firmware onto the M5Stick-C
A huge thank you (Dankjewel! :D) goes out to Thomas Mout for creating his project a year ago, the core of my code is based on his!
Looking for a solution for M5Stack over M5Stick-C? User lpv has forked my repo and optimized it for the M5Stack. Check his fork on GitLab
Hi, Guido!
I've been using your tally light system for some time now. I just received 8 m5stick c and I can't thank you enough. Your solution is affordable and it gives everyone a chance to have a multi tally light system.
I bought you a coffee when I first used this, and I'll buy you more. You've done a lot for the vMix community. Thank you my friend.
thanks 1 user thanked UzumyLemon for this useful post.
guidogast on 6/7/2022(UTC)
guidogast
#108 Posted : Tuesday, June 7, 2022 10:57:11 PM(UTC)
guidogast
Netherlands
Originally Posted by: UzumyLemon Go to Quoted Post
Hi, Guido!
You're very welcome. I'm glad everything works well for you. Every coffee is much appreciated :)
Follo
#109 Posted : Wednesday, May 22, 2024 4:15:26 AM(UTC)
Follo
Germany
Was thanked: 14 time(s) in 8 post(s)
can somebody tell me if this is working with the M5StickC PLUS2?
Thx
Luis70
#110 Posted : Wednesday, May 22, 2024 6:57:20 AM(UTC)
Luis70
Grenada
This seems great, but I found a free simple App that I can do all that with..... and if placed on a tablet, I can do switching and much more without having to touch the PC......its called vMix Panel Builder.....and it works great......wish I could have something like this to place on each camera.....something wireless.....
guidogast
#111 Posted : Saturday, May 25, 2024 2:54:01 AM(UTC)
guidogast
Netherlands
Thx
I haven't got the Plus2, so i can't test it, unfortunately.
eric.eventions
#112 Posted : Wednesday, June 26, 2024 6:24:45 PM(UTC)
eric.eventions
Singapore
Using the M5StickCPlus. Tried to follow all the steps but got these error
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\a_GLOBAL.ino:12:29: warning: extra tokens at end of #include directive
#include "k_PLUGINMANAGER.h";
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\c_MAIN.ino:139:42: warning: multi-character character constant [-Wmultichar]
String data = client.readStringUntil('\r\n');
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\c_MAIN.ino: In function 'void setup()':
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\c_MAIN.ino:36:11: error: unused variable 'c' [-Werror=unused-variable]
uint8_t c;
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\c_MAIN.ino: In function 'void loop()':
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\c_MAIN.ino:139:42: warning: unsigned conversion from 'int' to 'char' changes value from '3338' to ''\012'' [-Woverflow]
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\c_MAIN.ino: In function 'int getBatteryLevel()':
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\c_MAIN.ino:239:42: warning: 'uint16_t AXP192::GetVbatData()' is deprecated [-Wdeprecated-declarations]
uint16_t vbatData = M5.Axp.GetVbatData();
In file included from c:\Users\Eventions PC 2\Documents\Arduino\libraries\M5StickCPlus\src/M5StickCPlus.h:77,
from C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\a_GLOBAL.ino:4:
c:\Users\Eventions PC 2\Documents\Arduino\libraries\M5StickCPlus\src/AXP192.h:29:14: note: declared here
uint16_t GetVbatData(void) __attribute__((deprecated));
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\d_VMIX.ino: In function 'boolean connectTovMix(bool)':
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\d_VMIX.ino:27:10: error: unused variable 'tryCount' [-Werror=unused-variable]
char tryCount = 0;
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\e_WIFI.ino: In function 'void startLocalWiFi()':
C:\Users\Eventions PC 2\Downloads\vMix-M5Stick-Tally-Light-master\vMix-M5Stick-Tally-Light-master\src\a_GLOBAL\e_WIFI.ino:66:21: error: format '%s' expects argument of type 'char*', but argument 3 has type 'String' [-Werror=format=]
sprintf(apSsid, "vMix-M5Stick-Tally %s", WiFi.macAddress().substring(9, WiFi.macAddress().length()));
cc1plus.exe: some warnings being treated as errors
Multiple libraries were found for "WiFi.h"
Used: C:\Users\Eventions PC 2\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.1.1\libraries\WiFi
Not used: C:\Users\Eventions PC 2\Documents\Arduino\libraries\WiFiEspAT
Multiple libraries were found for "M5StickCPlus.h"
Used: C:\Users\Eventions PC 2\Documents\Arduino\libraries\M5StickCPlus
Not used: C:\Users\Eventions PC 2\Documents\Arduino\libraries\M5StickC-Plus
Using library M5StickCPlus at version 0.1.0 in folder: C:\Users\Eventions PC 2\Documents\Arduino\libraries\M5StickCPlus
Using library Wire at version 2.0.0 in folder: C:\Users\Eventions PC 2\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.1.1\libraries\Wire
Using library SPI at version 2.0.0 in folder: C:\Users\Eventions PC 2\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.1.1\libraries\SPI
Using library FS at version 2.0.0 in folder: C:\Users\Eventions PC 2\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.1.1\libraries\FS
Using library WiFi at version 2.0.0 in folder: C:\Users\Eventions PC 2\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.1.1\libraries\WiFi
Using library MultiButton at version 1.0.0 in folder: C:\Users\Eventions PC 2\Documents\Arduino\libraries\MultiButton
Using library WebServer at version 2.0.0 in folder: C:\Users\Eventions PC 2\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.1.1\libraries\WebServer
Using library Preferences at version 2.0.0 in folder: C:\Users\Eventions PC 2\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.1.1\libraries\Preferences
exit status 1
Compilation error: unused variable 'c' [-Werror=unused-variable]
eric.eventions
#113 Posted : Wednesday, June 26, 2024 8:38:16 PM(UTC)
eric.eventions
Singapore
Managed to get it working with 2.4.0 but the brightness is not adjustable.
Tried on Plus2, totally cant get it uploaded
ookujam
#114 Posted : Friday, May 9, 2025 7:09:17 AM(UTC)
ookujam
Hi Guido, I love your project and I was wondering if you are still working on it? I have some M5StickC Plus2 and sadly I can't get it running on them so if you or anybody else has a solution for that it would be highly appreciated! I'd even buy you a huuuuge coffee ;)
guidogast
#115 Posted : Wednesday, May 21, 2025 5:13:34 PM(UTC)
guidogast
Netherlands
Hi Ookujam,
Unfortunately, I'm not using them anymore, hence the development being stale. I have purchased an M5StickC Plus2 and will check if I can make it work with the current codebase. I'm not planning on rewriting anything, because that takes a lot of time. But if I can get a working version uploaded to the stick, I will post an instruction set on how to get it there :)
guidogast
#116 Posted : Wednesday, May 21, 2025 7:33:05 PM(UTC)
guidogast
Netherlands
I'm not making any promises, but I really like the way WLED let the users flash their software via a web interface to an ESP32 board. Will check if I can create a similar experience for users to make flashing the sticks a ton easier. It then doesn't require you to mess with the source code and it would be as easy as plugging in the stick, go to a site, select what version of the stick you have plugged in (in order to flash the correct version of the software) and click Install.
I will look into this when I have the time.
guidogast
#117 Posted : Thursday, May 22, 2025 7:27:13 AM(UTC)
guidogast
Netherlands
So I had an evening off and was pretty curious to see if I could make this installer thing work. It's still a work in progress, but here's a sneak peak.
No code, no hassle, just connect the stick, select your model from the dropdown, click install and select the COM port of the stick in the popup window. Wait about a minute and presto! The software is on the stick.
guidogast
#118 Posted : Saturday, August 16, 2025 11:30:25 PM(UTC)
guidogast
Netherlands
vMix M5StickC Tally Light Installer
The installer is now live. You can easily flash the firmware to your devices.
It works with the M5StickC and M5StickC Plus.
I really tried to get it working on the M5StickC Plus2 and got it compiling, but there's a bug that once you connect to it on your phone, the stick restarts. This makes it unusable. Need help from other developers to make the Plus2 work unfortunately. Hit me up on GitHub if you know the solution!
guidogast
#119 Posted : Saturday, December 20, 2025 12:29:57 AM(UTC)
guidogast
Netherlands
I'm happy to announce that the Plus2 stick is now supported! The new release (v2.5.0) can be installed through the web installer.
Guest (10)
6 Pages«<456
