Lastmarine
#1 Posted : Tuesday, May 13, 2025 7:05:19 PM(UTC)
Lastmarine
Hi there,
I have a Custom Laptop with a
12th Gen Intel(R) Core(TM) i7-1260P 2.10 GHz,
64gb RAM
Integrated Intel® Iris® Xe Graphics card
running Window 11 64bit
I'm trying to run a simple project at 720p25 with 3 video sources including a vCall, Desktop Webcam (arriving 1280x720) and a Desktop Capture.
Besides vMix I am running Serato DJ Pro which is also the software I am trying to capture via 'Desktop Capture' as a Desktop Capture input within the project (no audio capture).
Sadly the render times of the project once I maximize the Serato Window (which will run in the forground with vMix streaming in the background), instantly become 150-250ms which is obviously completely unsuitable.(pic attached). The CPU and GPU strain is low.
I am using vMix Desktop Capture software and had to uncheck GPU acceleration otherwise I just get a blank screen in vmix. I have tried reducing the Max Frame rate to as low as 5fps and yet still the render time on the project is 150+ms
Is my grfx card simply not compatible with this setup? Or is there something else I can do to help release strain?
Many Thanks in advance.
Chris
sinc747
#2 Posted : Saturday, May 17, 2025 3:27:08 PM(UTC)
sinc747
Was thanked: 205 time(s) in 171 post(s)
Hi Chris,
Have a look at the vMix Knowledge Base for articles relating to Performance, CPU, GPU, etc. Looks like your laptop doesn’t have an Nvidia graphics card which can contribute to the high Render Times.
Here’s an article to check: https://www.vmix.com/kno...-a-laptop-or-pc-for-vmix
Best wishes.
- Tom
